Author Topic: WMR89  (Read 514 times)
Offline tete
  • Win NT 10.0
  • Firefox 64.0
Re: WMR89
« Reply #15 on: February 02, 2019, 08:38:23 PM »
There is no software with the station or drivers.
The installer.exe that is provided in the support page of Oregon is full of errors, but for some miracle the drivers were installed.
Now everything is working there was no need for offsets all the data seems to be the same as the one in the main unit, just need to check the UV, but at this moment there is no sun...
Tete
Offline James42
  • Win 7/Srvr 2008R2
  • Firefox 60.9
Re: WMR89
« Reply #16 on: February 03, 2019, 03:43:26 PM »
Hi Brian
I now appear to have my three sensors working but under View, WMR918/68/R100 Extra Sensors I get the attached readings. All of the temperatures are correct, the humidity on sensor 3 is correct and the high/low temperatures on sensor 3 are correct. All other readings must be wrong. I would be grateful for your help.
Many thanks.
  • Davis VP2
  • New Zealand
  • Win NT 10.0
  • Chrome 71.0.3578.98
    • Weather Display
Re: WMR89
« Reply #17 on: February 03, 2019, 06:06:43 PM »
use the latest .zip update from the download page to fix
Offline James42
  • Win 7/Srvr 2008R2
  • Firefox 60.9
Re: WMR89
« Reply #18 on: February 04, 2019, 02:47:02 PM »
Hi Brian
Many thanks for the update.
I have used the latest zip file and I now have the readings as in the attached image.
Sensor 1 appears to all be correct.
Sensor 2 is missing times for the high /low humidity.
Sensor 3 the humidity is wrong, the high/low humidity and times are wrong, the temp high/low times are wrong.
I would be grateful for your help. Many thanks.
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
Re: WMR89
« Reply #19 on: February 04, 2019, 05:58:12 PM »
try a new .zip update
and click on reset for the hum hi/lo that are wrong and then see if the times show up correctly
Offline James42
  • Win 7/Srvr 2008R2
  • Firefox 60.9
Re: WMR89
« Reply #20 on: February 05, 2019, 02:27:28 PM »
Hi Brian
Many thanks that fixed it.
All is right now.
