WunderGround says not reporting!
Right mouse click on the file and select properties
See attached thanks.
Have not touched or changed anything for more than 2 years at least!
that is a strange place to find that file
where do you have WD installed?
the problem might be that you have the program that sends data to WU missing
try re installing WD (full install)
I backed up all the WD files, set a restore point, closed WD, downloaded and installed the latest version but WunderGround still not updating.
Screen grab attached.
where do you have WD installed to?
C: Drive - I just followed the reinstall instructions.
do you mean
c:\wdisplay
that is not where the file sentwudata.txt is that you are opening though in your screen shots
See attached
what does the file
sentwudata.txt
show
from that location
Hope this helps!
Many thanks
yes
but
what actually shows in that file
i.e double click on that file to open it up
at least now the modified date/time of the file is correct
10:55:01 a.m. 24/01/2019
http://weatherstation.wunderground.com/weatherstation/updateweatherstation.php?ID=IOTAGOAR6&PASSWORD=Tautau14&dateutc=2019-01-23+21%3A55%3A00&winddir=197&windspeedmph=0&windgustmph=0&humidity=60&tempf=50.2&rainin=0.000&baromin=29.565&dewptf=36.8&indoortempf=65.8&indoorhumidity=45&weather=CLR&clouds=&dailyrainin=0.000&soiltempf=&soilmoisture=&leafwetness=0.0&softwaretype=WeatherDisplay%3A10.37S&action=updateraw
OK
success
There is no reason why it should not work.
In my opinion, the main switch for updating the file is not turned on.
http://rtupdate.wunderground.com/weatherstation/updateweatherstation.php?realtime=1&rtfreq=3&action=updateraw&ID=IOLOMOUC23&PASSWORD=hyperon40&dateutc=2019-01-23+22%3A29%3A57&winddir=351&windspeedmph=5.9&windgustmph=8.0&humidity=86&tempf=24.7&rainin=0.000&baromin=29.679&dewptf=21.1&indoortempf=71.4&indoorhumidity=27&weather=SCT&clouds=&dailyrainin=0.000&solarradiation=0.0&soiltempf=34.0&soilmoisture=8.0&leafwetness=0.0&UV=0.0&softwaretype=WeatherDisplay%3A10.37S
OK
23:29:57
this is the URL
https://www.wunderground.com/personal-weather-station/dashboard?ID=IOTAGOAR6
according to the data being sent
and not
https://www.wunderground.com/personal-weather-station/dashboard?ID=IOTAGOAR2
is this not his
https://www.wunderground.com/personal-weather-station/dashboard?ID=IOLOMOUC23
Did a test data send and all ok!
Matrix posted his own data, that’s his WU site.
you don’t need to send a test
as its working
at
if you click on view your data in the wunderground setup in WD it will get taken to that url
I deleted the WunderGround web site. Zoomed into my site from another close by. Saved it and it is working fine. Don
if you clicked on view your data in the wunderground setup in WD then you would have got to your site
(which is the URL I have already posted)
