Hi My WS is located in Slovenia/Europe. I am add suneclipse and mooneclipse TAG “%mooneclipse%” and “%suneclipse%” on my web page but as I can see this data is calculated for Australia. I have correct input od Lat and Long on WD but calculation is the same for Australia and Oceania. Could somebody tell me which formula is applayed or what can be done that calculation will be made for Europe.
On my webpage is next mooneclipse 23:31 UTC 16 julij 2019 Eclipse Total and sun eclipse 21:23 UTC 2 julij 2019 Eclipse Total This is for Austalia/Oceania area.
Any idea around this ??
I just checked my moondetail2.gif for Netherlands.
We do have a moon eclips on Juli 16 23:31 but it is not a total eclips, only partially.
The next total eclips is next week on January 21 06:12 (Not mentioned in moondetail2.gif)
We do have a Total Sun Eclipse on July 2 but we are not able to see it.
The next Total Eclipse we can see is on August 12 2026.
Hi I have checked an I have correct data in Sun /mun coordinates. Here picture.
Next moon total eclipse on my area in set on 21.1.2019 and on web page also shows fool mon. But the tag shows next moon eclipse on 23:31 UTC 16 julij 2019 Eclipse Total
the problem is the component I use , for the moon eclipse, lat/long is not used
but I have found another calculation I can use and that does show the 21 jan eclipse for the northern hemisphere
so I can use
I will try that now and let you know
Hi Brian. Yep now workong OK for Moon eclipse . “21/januar/2019 04:12 (Local) 120%” ANd also max totality is correct 120%, thanks Brian…
Just waiting the update for sun data…
I think 120% is OK, just means that the “shadow” is that much bigger than the moon. So 100% would be a very short eclipse cause the shadow would only just cover the moon.
De verduistering heeft een grootte van 1.20 in de kernschaduw.De eclips begint om 3:36 uur en staat bij het maximum, om 6:13 uur, op een hoogte van circa 21
the minutes is correct but the hour is not, which is why I think the time zone is not being picked up correct
what is the time zone you have set in control panel, solar setup?
