Author Topic: sun/moon eclipse tag  (Read 1134 times)
Offline s52sk
  • Slovenia Europe
  • Win NT 10.0
  • Firefox 64.0
    • my weather station
« on: January 08, 2019, 10:22:31 AM »
Hi My WS is located in Slovenia/Europe. I am add suneclipse and mooneclipse TAG "%mooneclipse%" and "%suneclipse%" on my web page but as I can see this data is calculated for Australia. I have correct input od Lat and Long on WD but calculation is the same for Australia and Oceania. Could somebody tell me which formula is applayed or what can be done that calculation will be made for Europe.
On my webpage is next mooneclipse 23:31 UTC 16 julij 2019 Eclipse Total and sun eclipse 21:23 UTC 2 julij 2019 Eclipse Total This is for Austalia/Oceania area.
Any idea around this ??
Marco
« Last Edit: January 10, 2019, 03:51:53 PM by s52sk »
Offline s52sk
  • Slovenia Europe
  • Win NT 10.0
  • Firefox 64.0
Re: sun/moon eclipse tag
« Reply #1 on: January 11, 2019, 06:31:08 PM »
Any idea??
Online Weather Display
  • Davis VP2
  • New Zealand
  • Win NT 10.0
  • Chrome 71.0.3578.98
    • Weather Display
« Reply #2 on: January 13, 2019, 04:22:53 AM »
it should be using the lat/long you have set for the sun moon rise/set in WD
what have you set there?
Offline Weerstation
  • The Netherlands
  • Win NT 10.0
  • Mozilla compatible
« Reply #3 on: January 13, 2019, 08:54:32 AM »
I just checked my moondetail2.gif for Netherlands.
We do have a moon eclips on Juli 16 23:31 but it is not a total eclips, only partially.
The next total eclips is next week on January 21 06:12 (Not mentioned in moondetail2.gif)
We do have a Total Sun Eclipse on July 2 but we are not able to see it.
The next Total Eclipse we can see is on August 12 2026.
Vantage Vue (Firmware 2.14 EU) - WeatherDisplay 10.37S build 89 - USB Weatherlink IP Data Logger
Windows 10 Home 64-bit - HP Pavilion G7 Intel Core I3 2.4 GHz 4 Gb
Offline s52sk
  • Slovenia Europe
  • Win 7/Srvr 2008R2
  • Firefox 64.0
« Reply #4 on: January 13, 2019, 10:33:14 AM »
Hi I have checked an I have correct data in Sun /mun coordinates. Here picture.
Next moon total eclipse on my area in set on 21.1.2019 and on web page also shows fool mon. But the tag shows next moon eclipse on 23:31 UTC 16 julij 2019 Eclipse Total
CS Marco
« Last Edit: January 13, 2019, 10:37:07 AM by s52sk »
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #5 on: January 13, 2019, 08:24:46 PM »
the problem is the component I use , for the moon eclipse, lat/long is not used
but I have found another calculation I can use and that does show the 21 jan eclipse for the northern hemisphere
so I can use
I will try that now and let you know
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #6 on: January 13, 2019, 09:48:16 PM »
try a new .zip update of WD, ready now
I probably need to use this new routine for solar eclipse too? (as that did not have any location data in the routine I was using)
Offline s52sk
  • Slovenia Europe
  • Win NT 10.0
  • Firefox 64.0
« Reply #7 on: January 14, 2019, 06:15:36 PM »
Hi Brian. Yep now  workong OK for Moon eclipse . "21/januar/2019 04:12 (Local) 120%"              ANd also max totality is correct 120%, thanks Brian...
Just waiting the update for sun data..
Marco.
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #8 on: January 14, 2019, 06:22:44 PM »
OK, yes, I will do the same for the solar eclipse
so the 120% is correct?
as someone emailed me and asked about why is that above 100
Offline niko
  • syzygy
  • Global Moderator
  • Northern California, U.S.A.
  • Win 7/Srvr 2008R2
« Reply #9 on: January 14, 2019, 06:41:03 PM »
I think 120% is OK, just means that the "shadow" is that much bigger than the moon. So 100% would be a very short eclipse cause the shadow would only just cover the moon.
Offline mikeym
  • Thornhurst, Pa USA
  • Win 7/Srvr 2008R2
  • Firefox 64.0
    • MikeyMs Thornhurst,PA Weather
« Reply #10 on: January 14, 2019, 07:00:13 PM »
Brian the date is now correct, but the time isn't correct. My Lat/Long are 41.12 N  75.36 W
This is data from USNO:
Moon enters totality   2019 Jan 20  23:40.8       159.8     67.5
Middle of eclipse      2019 Jan 21  00:12.3       178.9     68.6
Moon leaves totality   2019 Jan 21  00:43.8       198.1     67.7
Cheers
 :D
MikeyM
« Last Edit: January 14, 2019, 07:45:58 PM by mikeym »
http://mikeymsweather.com/
Another VERY Happy WD user
Shuttle XS36v4 8 GB RAM
Davis Vantage Pro 2 wireless w/ Davis solar sensor
Laser Snow Depth Sensor LR4/Fluke 414D working in WD thanks to Brian
Offline Weerstation
  • The Netherlands
  • Win NT 10.0
« Reply #11 on: January 14, 2019, 07:36:28 PM »
From hemel.waarnemen.com for Netherlands and belgium
De verduistering heeft een grootte van 1.20 in de kernschaduw.De eclips begint om 3:36 uur en staat bij het maximum, om 6:13 uur, op een hoogte van circa 21 (in Utrecht).De eclips eindigt om 8:50 uur.Een totale maansverduistering kan erg indrukwekkend zijn. Tijdens de totaliteit, die duurt van 5:41 tot 6:44 uur, bevindt de Maan zich volledig in de kernschaduw van de Aarde en valt er geen direct zonlicht meer op de Maan.
Size of shadow is 1.20
Eclips begins at 3:36 max at 6:13 ends 8:50
Total eclips from 5:41 until 6:44
Thanks for the fix.
Can forward slashes be removed from the date?
« Last Edit: January 14, 2019, 07:38:57 PM by Weerstation »
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #12 on: January 15, 2019, 03:44:43 AM »
you don't mention what the time shows in WD Mikeym
Offline niko
  • syzygy
  • Global Moderator
  • Win 7/Srvr 2008R2
« Reply #13 on: January 15, 2019, 04:01:35 AM »
It's showing 10:12:29 (Local)  http://mikeymsweather.com/wxastronomy.php bottom of page
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #14 on: January 15, 2019, 07:30:43 AM »
the problem might be with the time zone
if you could email me your settings files mikeym
