*** closed*** HWS Template (WD34) Wish List
100% correct.
Thanks for jumping in, little busy here
Nice to have a BE flag and option. :slight_smile:
Is already there, a lot of multiple language countries have that “problem” so there is this general solution.
  1. copy and rename your countyry flag (for you be.svg) to xx.svg
    and
  2. select as “Your language/country flag” in the easyweather-settings the last one: “your country”
Thanks for your suggested change in the coding. I have implemented it.
What it appears to do is to bring into play the facility of being able to display the temps in fahrenheit. Correct?
My URL is Brisbane, Queensland Home Weather Station (cumulus version)
griffo42
Brisbane, Australia
Yes :slight_smile:
Hi!
Is it possible to get that when you click on the webcam and in the pop-up camera there is a live image or a video being displayed.
For my part, it is a timelapse [url]http://regnskvett.com/intraday_Video.mp4[/url
Torjan
This pop-up now shows your mp4.
webcam_popup.php.zip (1.84 KB)
Hi!
Thanks but it doesn’t work with me, look at the pagehttp://regnskvett.com/pws07/
You had to look into the script.
It contains the example code for your camera as a comment.
This one will show the webcam feed
webcam_popup.php.zip (1.86 KB)
Thanks! It worked. I tried but did not tick away the part about webcam image.
July release has different options for decimal places in barometric pressure. Could we have another easyweather option for baro pressure in integer hPa (no d.p.) / inHg to 2 d.p.? (Trend can stay offset by +1 d.p.)
WMR200 only provides integer hPa. . . :slight_smile:
The WMR200 and some other stations have a resolution of 1mb or 0,1inHg
The accuracy of a WMR200 is +/-10mb
Using 2 decimals for inHg even after recalculation from hPa to inHg would show an unreal precision.
Or did I misunderstood your question?
1 mb is 0,03 inHg
The [b]accuracy[/b] of a WMR200 is +/-10mb Using 2 decimals for inHg even after recalculation from hPa to inHg would show an unreal precision.
I agree entirely, but some visitors to my page might expect to see 2 d.p. for inHg, and would be surprised to see less. . .
Sorry I missed that resolution, it says indeed 1mb or 0,0inHg
So what you propose is always have 2 decimals for inHg?
I checked a few US sites and I found only sites with 2dp.
So to have that on your site change line 237 in w34_settings.php from
        $dec_baro++;
to
        $dec_baro=2;
Thanks, Wim. But then I think you still need to change lines 59 and 61 of baro_c_block.php to get the “Current” conversion right:
59 $dec_baro+1 to $dec_baro+2
61 $dec_baro-1 to $dec_baro-2
I can live with 1 d.p. for trend in hPa and 3 d.p. for trend in inHg: WD can produce a trend <1.0 hPa :wink:
Can we have “wind run” back? (Not in July release.)
Can we have “high rain rate/h for today”
It would be fine if there was a new topic for the October release, as most wishes are installed / taken care off.
For new users this topic is far too long and covers already three releases.
Good idea :slight_smile:
OK, I’ll lock this one up.
