Trivial point, but typo in Alert window: “Envirinment Canada” - should read “Environment Canada”.
#-o
Would like to see WXSIM module and Australia Warnings.
WXSIM is finalized and was tested past 2 weeks.
Australia warnings is on the ToDo list.
Regarding the downward arrow under the temp, is it possible to have that actually report Temp Rate? Yesterday we had a cold front move in and my WD indicated a temp drop of -5.8F/hr, yet the console pic below indicated -1F. What does it actually mean? It always show either +1 or -1F. Thanks.
Problem is known, the temp-rate is either 0, -1 or +1
There is an update (somewhere in the other topic), attached, which only displays the arrow and skips the value.
w34_livedata.php.zip (5.46 KB)
Wim, so there is no way to have it actually report the true value?
The attached script will do that, it calculate the trend based on the last-hour change in rain.
Please unzip and test.
Rain? Did you mean temp?
Yes, sorry
I added the script to the pwsWD folder. I don’t see a change yet. Might have to wait longer?
Probably you forgot to unzip as the current version on your server https://www.weather911.net/pwsWD/w34_livedata.php?sce=view does not has the change from the zip.
Your current version:
$weather["temp_trend"] = $wd[143]; // -1/0/1
the new version when you unzip it
$weather["temp_trend"] = (float) $wd[99] - (float) $wd[90]; # 2019-01-22 replace [143] which is login not value
IMPORTANT When you want support it is common decency to include a link to your site. Poeple who want to help have to see what is happening in the scripts.
So would you be so kind to include the link to your site in your avatar-block. That is the the block on the left of every post you do. The small globe should lead to your index.php If there is a specific page you want to discuss about, always supply the full link.
Most persons on this forum are not clairvoyant, sadly.
Really folks, please try to make it easy for the helpful people on here to help you!
But unfortunately we do have a lot of practice
Thanks a lot. All working good now. I sure have learned a lot in the last week.
Unless I missed it I would like to see this function added…
I have earthquake data displayed top row box 3 (webcam in main window bottom row middle box). If I change to show earthquake data in main window instead of the webcam, when I click on that box it pops up a window showing multiple recent earthquakes. Could this function be added to the top row box, so when clicked, it brings up that same pop up window? I want to keep the webcam but I also would like the ability to bring up the recent earthquake pop up.
Thank you for your fantastic work.
I have testet feb 18 beta using WeeWx to generate realtime.txt output from Vantage Pro2.
I would like to see the option allow for both webcam and UV in the two bottom blocks.
The top blocks have no room to add links. Adding would need extra room increasing the height further. The whole idea is that this template should fit on an iPad without scrolling.
But I added the earthquake to the current-conditions blocks. Current-conditions only have a metar pop-up, so there is room.
The July release will have no “fixed” choices. All blocks will operate on all places.
But for the April release I adapted the easyweather script so that those two blocks have the same set of choices.
Testing at https://sluispark.be/pwsTEST/ as I needed a WLIP-logger to test with
I know we get to choose the rain rate units, but I still think the units should be shown in the Rainfall block. Please. . .
