I have just changed site hosts after many years and am trying to sort out the weather on the new site.
After configuring the new FTP details the WD Live files update as they should. The averages and extremes etc also upload no problem. The webcam image, main screen shot and weather web page wont upload. Logs onto site ok but then says directory does not exist. This is the same directory that it uploads WD Live files, averages etc. I presume that it uses the same FTP program for all uploads?
I have just tried as you suggested but get the same error. I did find however when looking at the Live FTP log that it also reports the error but still uploads to the directory it says doesn’t exist.
Clientdraw.txt, clienthour.txt, clientrawextra.txt and clientrawdaily.txt all update as normal when /public_html/wx/ is used, even though it reports the same “No such file or directory”.
I can upload the file manually using another FTP program by selecting the directory and doing a manual upload. Just fails on WD.
You are correct and a typo set in I’m afraid. The directory is lower case and was actually set as such. I have however checked the following to be sure.
@Edd: Try this so we know in which directory you land when connecting by FTP:
Try this
Open a Windows command window (cmd.exe)
At the prompt type ftp yourservername
and hit return
respond to user and password prompts
you should now be logged in
type pwd
and hit return
