Author Topic: problem with the noaareportyyyy.htm  (Read 308 times)
Offline Thornbury Weather
  • Thornbury Bristol UK
  • Win NT 10.0
  • Chrome 71.0.3578.98
    • Thornbury Weather
« on: January 07, 2019, 08:21:00 AM »
I have a problem with the noaareportyyyy.htm
The heading which gives the units has Temp in F & Rain in in. & windspeed in MPH
The data is in C, mm, mph
I have looked back through the last 11 years & its always been like this
http://www.thornburyweather.co.uk/weatherstation/noaareportyear2018.htm
The dailynoaareportmmyyyy.htm has the heading units in C. mm, mph which is correct & matchers the data. http://www.thornburyweather.co.uk/weatherstation/dailynoaareport122018.htm
I have check another site in the uk which users weather display & the same units & has the same problem.
Is this a problem or did I miss something when I set up weather display?
Can I correct this?
Davis Vantage Pro2 with solar detector
Davis Leaf & Soil Temperature Station
+1 wire temperature (5)
Online Weather Display
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
Re: problem with the noaareportyyyy.htm
« Reply #1 on: January 07, 2019, 06:27:53 PM »
I am not seeing that here
http://weather-display.com/windy/gb/noaareportyear2018.htm
check your settings under
view,av/ext
noaa report
setup
  • Win NT 10.0
    • Thornbury Weather
« Reply #2 on: January 07, 2019, 10:21:38 PM »
thanks for your reply.
I cant see how to change the units.
i can edit change the heading units on the page but ok dose not keep the units when the page is reopened.
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #3 on: January 07, 2019, 10:45:24 PM »
what version/build of WD?
  • Win NT 10.0
    • Thornbury Weather
« Reply #4 on: January 08, 2019, 08:02:01 AM »
i am using 10.37S85
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #5 on: January 08, 2019, 09:03:33 AM »
if you could email me your settings files, I will test/check here
  • Win NT 10.0
    • Thornbury Weather
« Reply #6 on: January 08, 2019, 09:19:19 AM »
Email with zip file sent
Steve
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #7 on: January 08, 2019, 09:24:18 AM »
OK
the issue is, you are using mph for windspeed units (instead of the metric kmh)
and so WD is thinking you must be using non metric
I will change that
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #8 on: January 10, 2019, 06:36:48 PM »
been away for a couple of days sorry
try the latest .zip update
it should fix this issue
  • Win NT 10.0
    • Thornbury Weather
« Reply #9 on: January 10, 2019, 10:19:01 PM »
thanks for looking at this problem
the yearly report has changed
Temperature & Rain units header are now correct.
but it now shows m/s for wind speed instead of mph
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #10 on: January 11, 2019, 04:47:14 AM »
my bad
was in a hurry as was shifting our daughter into a new flat today
download again
  • Win NT 10.0
    • Thornbury Weather
« Reply #11 on: January 11, 2019, 07:38:19 AM »
looks like the problem is fix now
Thank you for spending some of your time on this
Steve
