I need to replace my 13 years hold Honeywell TE923W and after making a lot of search, I have narrowed my choice to the WS-2902A.
The Amazon customers review is very positive
WD uses the data from the Ambient server (API)
so you need to have the station setup to send data to the Ambient server
the update rate I think is not as fast as it used to be? (now fastest is 1 minute?)
someone needs to find out…
its possible it might work
more info here
http://kona2.alc.upv.es/Estacio_Meteorologica/aercusWDsetup.htm
The
it should not affect your data
you just change the station type in WD and then restart WD
try to get the barometer to match up with what you had in the data though maybe
OK, I just ordered the HP3500B from Amazon and I give you a follow-up next week
I just receive my new HP3500B but I can
