There has been numerous extra pages and scripts. Some are added. such as WXSIM.
Please add your “requests for enhancements” to the “wish-list” topic, and include some sort of screenshot.
I am fairly new to these scripts and have no history of all extra’s from the past.
Hi, my big temp disappears after a short time for some reason, refresh the page and it comes back, also in the marked area, its foreign text.
I am also trying to update the wind speed and direction to every 2 seconds, when i count it appears to be around 40 seconds yet in the settings they were set to 16 which does not match what its doing (40s) i changed them to 2 anyway but i have a feeling it might not even be that file (WD34_settings.php)?
Maybe: The temp script fails when there is an incomplete upload.
I could not replicate that. I waited about 10 automatic reloads and the area remains unaffected. Questions: What browser do you use? Does it happen with other browsers? Which provider?
There are a lot of “regional” languages for the DarkSky forecast. There is a setting nearly at the bottom where you select the language for the DarkSky forecast. After you change that and save the settings, please wait max 1 hour until the cached 9dutch) forecast is replaced with one with your selected language
HI Wim, thank you for the reply, i am using Chrome on 2 laptops both and both do the same with the temp, very strange, when you say provider, i assume you mean, hostgator or 1and1 etc, well its my own Kimsufi server. I still have an older version running here and that temp works ok
Regarding the forecast settings, its set to English (Which is the default) already, i didnt change that, i will wait for the hour to pass
I did amend my reply adding the part about the wind speed update times, i will like them at 2s and have adjusted the setting but the default was 16s, yet when i count it they are at about 40s so that does not match the default at 16. I have them at 2 second in the older version as show here, there are 3 pages that have the same settings so i changed all 3, perhaps i missed one wd34_settings.php, wd34_settings1.php and wd34_settings copy.php
The big temp appears to disappear after 5 minutes., just loaded MS Edge and IE9 and FF to test those
Those are totally different versions, much of the code is changed.
I will investigate deeper / longer. Maybe an incomplete load of the block contents.
Are other blocks affected, or do they look normal?
http://www.brecklandweather.com/pwsWD/forecastDShourly_popup.php =>The texts are all in Dutch
./jsondata/darksky.txt => all in Dutch
So I think there is a typing error with the DarkSky API-key
You need that to display the bottom part of the current conditions block, that part shows the current/expected conditions for this/coming hour.
The individual refresh-times can be altered in w34_blocks.php
A fast check at http://www.brecklandweather.com/pwsWD/w34_blocks.php?sce=view shows that the refresh-time is default 40 seconds. External providers do not like multiple users refreshing the blocks at 2 seconds as that involes loading multiple .PHP scripts and data-sets.
Thank you Wim, thats sorted the refresh times, i have no issues with my server and refresh times, for y clients at add them to a white list that prevents them from being affected by the firewall and cphulk, i/they could use 1 seconds (if wanted) and we wouldnt be affected. But yes, many providers do not like this but this is the benefit of having your own server, you can set it to how you like
Re the temp, all the browser return the same issue, thats FF, Chrome, IE and Edge
Re the dark sky side of things, i have just checked the api and the code is totally different to what it was when i used it for the previous script, very strange, i have updated it to the new api code and now awaiting any change, all the other blocks appear ok…
I have just clicked on the Nearby link and that opens the METAR, i have changed the airport in the settings and just double checked yet its still showing your default METAR (EBBR Brussels) perhaps ths has not cached yet?
Where are you located? This is the latitude / longitude you used, according to DarkSky?
[latitude] => 0.6136
[longitude] => 52.4636
This is the answer from DarkSky in your browser: https://darksky.net/forecast/0.6136,52.4636/ca12/en
Middle of Nowhere
If you are in the UK somewhere near Brandon it should be switched.
Please do not use this type of timezone: [timezone] => Etc/GMT-3
Use one of these PHP: Europe - Manual as they will switch automatically for daylight savings time.
contents of "./jsondata/metar34.txt", processed as filetype "text file"
Filetime (UTC): 2019-03-29T16:40:44+00:00 which an age of 16 hrs 18 min 34 seconds
The filetimes show that the data is never refreshed.
==> click “Load files” at the bottom
w34_load_files.php (59) METAR not loaded API=ADD YOUR API KEY
The metar-api key was not entered as it still contains the default value.
HA HA, yep, definitely not there, i wish, i took the long/lat from google, i will have another look at that, thanks,
(from Your location to 52.4633865, 0.6601383) i got it from the link in the settings, but i think i had them the wrong way round and missed off the - so corrected both, so must be a waiting game for it to cache now as the popup is still the same.
I didnt notice anything about a METAR api, just adding the airport code, so i will have another look at that too, (just done it and now working) thank you
Did you see the part about the temp disappearing being only on the Dark theme? no rush as the Light theme is ok thanks again for your time Wim
OK, looking good so far Wim, that erronous forecast temp is now down from 29C to a more UK realistic summer figure of 14C, yeah i know, go figure, it 30C+ most of last years summer lol
I did test the temperature_small.php and when i 1st did so there was an error, but not since and i didnt record it, typical, it think it said line 480, i will monitor that, but if you ever need access to test this last big temp issue, i have no issues with that, just shout me and i will let ya know the password.
It seems that when running the dark theme. it sometimes happens that a global variable $theme does not keep its value.
It switches from “dark” to “???” => the scripts use “light” then
So when you start with dark the css for dark is loaded and the classes used in the code are correct in the css
<div class="circleOut">
<div class="temperaturecircle"></div>
<div class="temptextmild">12.1<suptemp>°</suptemp></div>
</div><!-- end circleOut -->
When the change to “???” occurs the CSS loaded is still the dark one but the code now changes to
Those classes are not in the light-css so the colors are not displayed.
When starting with “light” light theme the light css is loaded.
When $theme changes to “???” there is no problem as the generated code remains the same.
I have multiple windows open on my test servers for over 30 minutes but the changes do not occur at my test-site.
For me, it shows when starting with dark or light and starting with light and then switch to dark, i only know this for sure because ive only just done that with my tablet using Chrome browser, i have to nip off for a couple of hours so if i dont reply im not being rude.
