You should test the latest beta fro March 1, is as good as the April release, but it still has all error reporting switched on.
http://wd34.weather-template.com/beta.php
Corrected on both points. All menu items are now translated. So "FIRST SETUP (protected) " can be translated also.
Check the latest beta at http://wd34.weather-template.com/pwsTEST/index.php?lang=nl
I will update the other language files before the end of March and will also move the english .php to a .txt file also.
In April release there is a “lightgrey” background-color.
<img src="http://www.weewx.com/weewx-logo-128x128.png" width="35" height="35" alt="Weewx"
style="background-color: lightgrey; padding: 2px;">
Looks good in Dark and Light I think.
Good job, Wim! (But the “FIRST SETUP” heading “Instellingen” is in cap and lower case?)
One can translate as one wants.
|FIRST SETUP|INSTELLINGEN|
of
|FIRST SETUP|Instellingen|
But it would be better to be more consistent, :oops:
I prefer lowercase as it reads easier. So I changed the language file for Dutch to have lowercase entries in the menu.
Should this code snippet be inserted into w34_index.php?
No this is strictly BETA.
In the beta/April release I moved the images from index.php and the frames.php to the settings. So that we can add and change it at one place without changing at multiple others.
w34_cron_stationcron.php is not executed. I can run it manually using _test.php?test=w34_cron_stationcron.php.
Thank you!
Sorry to Wim that I forgot to include url
My problem is that cron job is not executed.
I use WeeWX. WDapi is not possible with current setup.
http://weather.meisal.com
Cronjobs are started from somewhere else and only executed on your weather34/ website.
WeatherPrograms such as WeatherDisplay or Meteobridge are able to function as a cron-server themselves.
Small linux computers such as RaspBerry have built in cron-servers also.
Or you can use a free (or almost free) con-provider.
There are multiple discussions on the weather-fora about which providers can be used.
Sometimes your website provider has a free cron service also.
Some of the names I got when using Google Free cronjobs - from minutely to once a year. - cron-job.org https://www.cronjob.de/ https://www.setcron.com/
But this topic/discussion is not the right place and by hiding it here in this topic you will get far less answers than starting a topic such as" Which (free) cronjob server should I use?"
This states why the script is not executed when not using programs like WeatherDisplay.
It was not very clear anywhere that I need to create a cron job myself. At least could not find it anywhere.
With this knowledge I’m able to move forward.
Thank’s again for helping!
Ended up defining this cron task:
*/1 * * * * /usr/bin/php -q /home/weather/public_html/w34_cron_stationcron.php
I verified it is running once every minute and updates MYSQL db and csv file as expected
I assume I will also need two additional jobs running w34_cron_addtoyear.php and w34_cron_empty.php.
Correct?
Confirming that I do not upload to WeatherUnderground.
I should be good to go then.
G400
Yes, you need the two other cron-jobs also. Wim
I updated to your new template Wim today
good job Wim
was relatively easy
I do see one error, might be that my php version 5.5.38 is a bit below minimum, and that is the moon phase script
http://weather-display.com/pwsWD/
Fatal error: Class ‘Moon’ not found in /homepages/22/d75034112/htdocs/weather-display/english/pwsWD/moon_block.php on line 42
I also see Overwegend bewolkt in the current conditions ( I set to use clientraw for that)
