Author Topic: ***closed*** weather34 for WeatherDisplay (clientraw and WDapi)  (Read 23372 times)
Offline wvdkuil
  • Wim van der Kuil
  • Leuven Belgium CET
  • Mac OS X 10.13.6
  • Chrome 72.0.3626.119
« Reply #390 on: March 02, 2019, 04:15:32 PM »
Still having problems with the metar...
:oops:
forgot to update the pwsWD/ version also. Attached a new version of the script
Offline NorCal Dan
  • Dan - KJ6RGX
  • Davis Vue/Win10
  • Ocean Park, WA.
  • Mac OS X 10.10.5
    • Traveling RV Weather
« Reply #391 on: March 02, 2019, 04:27:11 PM »
:oops:
Good deal.  Anxiously awaiting the April release...
Offline wvdkuil
  • Wim van der Kuil
  • Mac OS X 10.13.6
« Reply #392 on: March 02, 2019, 04:47:56 PM »
You should test the latest beta fro March 1, is as good as the April release, but it still has all error reporting switched on.
http://wd34.weather-template.com/beta.php
Offline wvdkuil
  • Wim van der Kuil
  • Mac OS X 10.13.6
« Reply #393 on: March 03, 2019, 02:56:04 PM »
Still on the subject of Menu headings, I find it strange that "Settings" is headed "FIRST SETUP" because it is only FIRST the first time you use it.
I use Settings three or four times a day  :)
Corrected on both points.  All menu items are now translated.  So  "FIRST SETUP (protected)  " can be translated also.
Check the latest beta  at  http://wd34.weather-template.com/pwsTEST/index.php?lang=nl
I will update the other language files before the end of March and will also move the english .php  to a .txt file also.
Offline wvdkuil
  • Wim van der Kuil
  • Mac OS X 10.13.6
« Reply #394 on: March 03, 2019, 03:08:04 PM »
Perfect! Works like a charm.
However, official WeeWX logo does not look good on black background, but that is not anything we expect you to fix :-)
In April release there is a "lightgrey" background-color.
Code: [Select]
<img src="http://www.weewx.com/weewx-logo-128x128.png" width="35" height="35" alt="Weewx"
         style="background-color: lightgrey; padding: 2px;">
Looks good in Dark and Light I think.
« Last Edit: March 03, 2019, 03:41:06 PM by wvdkuil »
Offline bitsostring
  • Oregon Scientific WMR200
  • Edinburgh, U.K.
  • Chrome 64.0.3282.140
    • Home Weather Station
« Reply #395 on: March 03, 2019, 03:11:28 PM »
Good job, Wim! (But the "FIRST SETUP" heading "Instellingen" is in cap and lower case?)
It's meant to be fun. . .
Offline wvdkuil
  • Wim van der Kuil
  • Mac OS X 10.13.6
« Reply #396 on: March 03, 2019, 03:20:45 PM »
One can translate as one wants.
|FIRST SETUP|INSTELLINGEN|
of
|FIRST SETUP|Instellingen|
But it would be better to be more consistent,  :oops:
I prefer lowercase as it reads easier. So  I changed the language file for Dutch to have lowercase entries in the menu.
Offline GW400
  • Klepp, Norway
« Reply #397 on: March 03, 2019, 06:37:52 PM »
Code: [Select]
Should this code snippet be inserted into w34_index.php?
Regards G400
Offline wvdkuil
  • Wim van der Kuil
  • Mac OS X 10.13.6
« Reply #398 on: March 03, 2019, 07:25:48 PM »
No this is strictly BETA.
In the beta/April release I moved the images from index.php and the frames.php to the settings. So that we can add and change it at one place without changing at multiple others.
Offline GW400
  • Klepp, Norway
« Reply #399 on: March 03, 2019, 09:23:46 PM »
w34_cron_stationcron.php is not executed. I can run it manually using _test.php?test=w34_cron_stationcron.php.
Regards G400
Offline wvdkuil
  • Wim van der Kuil
  • Mac OS X 10.13.6
« Reply #400 on: March 04, 2019, 07:25:46 AM »
  • What is the URL?
    PLEASE understand that you are not the only one using these scripts and I have to support my own scripts also on four forums in multiple languages.  I am not clairvoyant and can not remember every individual request
  • As you state that the cron-job runs from the browser,  there seems to be no problem with the cronjob itself.
    So please tell me what your problem is.
  • Adding  _test.php only adds the display of all debug info.
    Do not use that when running a job from WeatherDisplay or whatever cron-server-program you are using.
    Cron servers do not like to get large blobs of data from the jobs they start.
  • http://wd34.weather-template.com/documentation/WDapi-stationcron-2019-01.pdf
« Last Edit: March 04, 2019, 08:13:15 AM by wvdkuil »
Offline bitsostring
  • Edinburgh, U.K.
Offline GW400
  • Klepp, Norway
« Reply #402 on: March 04, 2019, 02:36:43 PM »
Thank you!
Sorry to Wim that I forgot to include url :-(
Regards G400
Offline GW400
  • Klepp, Norway
« Reply #403 on: March 04, 2019, 02:40:10 PM »
  • What is the URL?
My problem is that cron job is not executed.
I use WeeWX. WDapi is not possible with current setup.
http://weather.meisal.com
Regards G400
Offline wvdkuil
  • Wim van der Kuil
  • Mac OS X 10.13.6
« Reply #404 on: March 04, 2019, 02:57:05 PM »
Cronjobs are started from somewhere else and only executed on your weather34/ website.
WeatherPrograms such as WeatherDisplay  or Meteobridge are able to function as a cron-server themselves.
Small linux computers such as RaspBerry have built in cron-servers also.
Or you can use a free (or almost free) con-provider.
There are multiple discussions on the weather-fora about which providers can be used.
Sometimes your website provider has a free cron service also.
Some of the names I got when using Google   https://cron-job.org/en/  https://www.cronjob.de/  https://www.setcron.com/
But this topic/discussion is not the right place and by hiding it here in this topic you will get far less answers than starting a topic such as" Which (free) cronjob server should I use?"
