keep up the good work Wim
we all appreciate your dedication
My apologies again ! #-o
As for myself, I work for one of the top computer companies in the world with 135,000+ employees in over 300 countries and the term RFE ( Request for Enhancement ) has always been understood in any conversation I’ve had with anyone anywhere and is considered universal.
That being said … I shall refrain from using any abbreviations in future outside of the work environment in this forum
regards
Tim
Something funny in the Nearby metar pop-up this morning. . . Is this a CheckWX problem?
Suddenly all metar pop-ups, old or new, show a date of 1-1-1970 UTC and an error message when error reporting is on.
And you are the first to notice it? Thanks
First make a copy of the current script and please test this version,
P.S. “Is this a CheckWX problem” => yes
The date field in the json file now contains something more then the expected string:
"observed":"17-02-2019 <span class=\"tx-light tx-12\">@<\/span> 11:00Z",
metar_popup.php.zip (7.11 KB)
New version shows the wrong time: 00:20 am instead of 1120Z (UTC).
. . . and later 00:50 am instead of 1150Z.
Yes the invalid data is still there, so the time fields are more or less valid.
The “garbage in” results in “garbage out” for the time field, but without large error messages.
The unexpected values are still there, but shorter
"observed":"17-02-2019 @<\/span> 12:00Z"
Second beta version April release ready for download.
Read more at and download from http://wd34.weather-template.com/beta.php
Comments welcome at HWS-template (WD34) beta test topic
Do not update the beta releases, just remove old folder and test the new one from scratch, thanks
So there is nothing I can do about it?
i assume it will go away, but I modified the script a bit and see if this removes the extra unneeded characters.
metar_popup.php.zip (7.1 KB)
That’s looking good. Thanks, Wim.
Thought I’d contact CheckWX anyway, here’s their reply:
“Thanks for bringing this issue to our attention. It has been corrected.
I apologize for the inconvenience and thank you for using CheckWX”
It may be that Dutch is the only language file with that phrase, it doesn’t appear, e.g., in the current French or German language files. . . I haven’t checked them all. In French and German the entries are just |language|choisir… or |language|sprache
Looks like the metar34.txt has changed again the popup gives error 500 in IE11 and edge says something about humidity and line 103 in the metar_load_funct.php it was ok early this morning
http://www.hc-iom.co.uk/pwsWD/index.php
{“results”:1,“data”:[{“icao”:“EGNS”,“name”:“Isle of Man”,“observed”:“21-02-2019 @ 16:50Z”,“raw_text”:“EGNS 211650Z 15009KT 9000 FEW006 10/08 Q1023 NOSIG”,“barometer”:{“mb”:1022.92,“hg”:30.21,“kpa”:102.29},“clouds”:[{“code”:“FEW”,“base_feet_agl”:600,“base_meters_agl”:600,“text”:“Few”}],“dewpoint”:{“celsius”:8,“fahrenheit”:46},“elevation”:{“feet”:55.77,“meters”:17},“flight_category”:“VFR”,“humidity”:{“percent”:88},“temperature”:{“celsius”:10,“fahrenheit”:50},“visibility”:{“miles”:“559”,“miles_float”:5.59,“meters”:“8,996”,“meters_float”:8996.23},“wind”:{“degrees”:150,“speed_kts”:9,“speed_mph”:10,“speed_mps”:5}}]}
Yes they changed the API and the humidity was a string “humidity”: 88, is now an array: “humidity”:{“percent”:88}
Attached new version of script for the normal release pwsWD! Do not for beta test pwsTEST.
metar_load_funct.php.zip (3.66 KB)
Metar pop-up working OK here in Chrome, Edge and IE11.
No, it’s not! Pop-up is working, humidity isn’t. . . Sorry #-o
Not anymore at 21:25 CET,
Thanks Wim that sorted it, why they keep changing it is another question
+1
Still on the subject of Menu headings, I find it strange that “Settings” is headed “FIRST SETUP” because it is only FIRST the first time you use it.
I use Settings three or four times a day
