Hi Wim,
Just installed your BETA test code that includes Cumulus support.
You can see my site here… http://weather.skybase.net/pwsTEST/index.php
Everything is working except for METAR retrieval. Clicking on Current conditions → “Nearby” produces the errors below …
Warning: Illegal string offset 'observed' in /var/www/html/pwsTEST/metar_load_funct.php on line 50
Warning: Illegal string offset 'raw_text' in /var/www/html/pwsTEST/metar_load_funct.php on line 51
Warning: Illegal string offset 'icao' in /var/www/html/pwsTEST/metar_load_funct.php on line 52
Warning: Illegal string offset 'name' in /var/www/html/pwsTEST/metar_load_funct.php on line 53
Warning: Illegal string offset 'barometer' in /var/www/html/pwsTEST/metar_load_funct.php on line 54
Warning: Illegal string offset 'hg' in /var/www/html/pwsTEST/metar_load_funct.php on line 54
Warning: Illegal string offset 'barometer' in /var/www/html/pwsTEST/metar_load_funct.php on line 55
Warning: Illegal string offset 'mb' in /var/www/html/pwsTEST/metar_load_funct.php on line 55
Warning: array_key_exists() expects parameter 2 to be array, string given in /var/www/html/pwsTEST/metar_load_funct.php on line 78
Warning: Illegal string offset 'clouds' in /var/www/html/pwsTEST/metar_load_funct.php on line 88
Warning: Illegal string offset 'code' in /var/www/html/pwsTEST/metar_load_funct.php on line 88
Warning: Illegal string offset 'clouds' in /var/www/html/pwsTEST/metar_load_funct.php on line 89
Warning: Illegal string offset 'text' in /var/www/html/pwsTEST/metar_load_funct.php on line 89
Warning: Illegal string offset 'dewpoint' in /var/www/html/pwsTEST/metar_load_funct.php on line 91
Warning: Illegal string offset 'celsius' in /var/www/html/pwsTEST/metar_load_funct.php on line 91
Warning: Illegal string offset 'dewpoint' in /var/www/html/pwsTEST/metar_load_funct.php on line 92
Warning: Illegal string offset 'fahrenheit' in /var/www/html/pwsTEST/metar_load_funct.php on line 92
Warning: Illegal string offset 'temperature' in /var/www/html/pwsTEST/metar_load_funct.php on line 93
Warning: Illegal string offset 'celsius' in /var/www/html/pwsTEST/metar_load_funct.php on line 93
Warning: Illegal string offset 'temperature' in /var/www/html/pwsTEST/metar_load_funct.php on line 94
Warning: Illegal string offset 'fahrenheit' in /var/www/html/pwsTEST/metar_load_funct.php on line 94
Warning: Illegal string offset 'humidity_percent' in /var/www/html/pwsTEST/metar_load_funct.php on line 95
Warning: Illegal string offset 'visibility' in /var/www/html/pwsTEST/metar_load_funct.php on line 96
Warning: Illegal string offset 'meters' in /var/www/html/pwsTEST/metar_load_funct.php on line 96
Warning: Illegal string offset 'wind' in /var/www/html/pwsTEST/metar_load_funct.php on line 97
Warning: Illegal string offset 'degrees' in /var/www/html/pwsTEST/metar_load_funct.php on line 97
Y
