As most English language words/word-groups do not have to be translated there is no new translation-file for en.
The old structure is used in . . /languages/lang.en.php
You should remove the typo by adding this to the end of the file:
$lang['Select langauge'] = 'Select language';
In all other language files (f.i. Dutch) it is
 |Select langauge|Selecteer een taal|
On the left always the words from the scripts, on the right the translation.
Typing errors for the English words should be handled by the language files.
If you changes texts in the scripts as you did, the language files for the other languages will not find the correctly spelled words.
Thanks, Wim. I obviously didn’t read your earlier instructions properly. . . all OK now.
Wim,
Thanks, that did it. Great work.
Hi Wim,
Just installed your BETA test code that includes Cumulus support.
You can see my site here… http://weather.skybase.net/pwsTEST/index.php
Everything is working except for METAR retrieval. Clicking on Current conditions → “Nearby” produces the errors below …
Warning: Illegal string offset 'observed' in /var/www/html/pwsTEST/metar_load_funct.php on line 50
Warning: Illegal string offset 'raw_text' in /var/www/html/pwsTEST/metar_load_funct.php on line 51
Warning: Illegal string offset 'icao' in /var/www/html/pwsTEST/metar_load_funct.php on line 52
Warning: Illegal string offset 'name' in /var/www/html/pwsTEST/metar_load_funct.php on line 53
Warning: Illegal string offset 'barometer' in /var/www/html/pwsTEST/metar_load_funct.php on line 54
Warning: Illegal string offset 'hg' in /var/www/html/pwsTEST/metar_load_funct.php on line 54
Warning: Illegal string offset 'barometer' in /var/www/html/pwsTEST/metar_load_funct.php on line 55
Warning: Illegal string offset 'mb' in /var/www/html/pwsTEST/metar_load_funct.php on line 55
Warning: array_key_exists() expects parameter 2 to be array, string given in /var/www/html/pwsTEST/metar_load_funct.php on line 78
Warning: Illegal string offset 'clouds' in /var/www/html/pwsTEST/metar_load_funct.php on line 88
Warning: Illegal string offset 'code' in /var/www/html/pwsTEST/metar_load_funct.php on line 88
Warning: Illegal string offset 'clouds' in /var/www/html/pwsTEST/metar_load_funct.php on line 89
Warning: Illegal string offset 'text' in /var/www/html/pwsTEST/metar_load_funct.php on line 89
Warning: Illegal string offset 'dewpoint' in /var/www/html/pwsTEST/metar_load_funct.php on line 91
Warning: Illegal string offset 'celsius' in /var/www/html/pwsTEST/metar_load_funct.php on line 91
Warning: Illegal string offset 'dewpoint' in /var/www/html/pwsTEST/metar_load_funct.php on line 92
Warning: Illegal string offset 'fahrenheit' in /var/www/html/pwsTEST/metar_load_funct.php on line 92
Warning: Illegal string offset 'temperature' in /var/www/html/pwsTEST/metar_load_funct.php on line 93
Warning: Illegal string offset 'celsius' in /var/www/html/pwsTEST/metar_load_funct.php on line 93
Warning: Illegal string offset 'temperature' in /var/www/html/pwsTEST/metar_load_funct.php on line 94
Warning: Illegal string offset 'fahrenheit' in /var/www/html/pwsTEST/metar_load_funct.php on line 94
Warning: Illegal string offset 'humidity_percent' in /var/www/html/pwsTEST/metar_load_funct.php on line 95
Warning: Illegal string offset 'visibility' in /var/www/html/pwsTEST/metar_load_funct.php on line 96
Warning: Illegal string offset 'meters' in /var/www/html/pwsTEST/metar_load_funct.php on line 96
Warning: Illegal string offset 'wind' in /var/www/html/pwsTEST/metar_load_funct.php on line 97
Warning: Illegal string offset 'degrees' in /var/www/html/pwsTEST/metar_load_funct.php on line 97
Y
The data retrieved for your airport
{"results":1,"data":["YRSI Invalid Station ICAO"]}
You entered at question "Enter your nearest airport code (XXXX) . . . " an invalid code YRSI
That airport does not exist: List of airports by ICAO code: Y - Wikipedia
Doh!
I had a dyslexic moment, it should be YSRI. :oops:
I looked at that maybe ten times and didn’t see the problem :x
thanks
Tim
Hi Wim,
Now that I’ve had a little more time to do some testing I have found the following…
In the Moon phase pop-up the text is not fitting into the boxes, bottom box edges are across the text
The acknowledgement “Design based on weather34.com” on the bottom right is off the page
The site wont run on older Safari versions i.e.
“GET /pwsTEST/index.php HTTP/1.1” 200 5870 “-” “Mozilla/5.0 (iPad; CPU OS 9_3_5 like Mac OS X) AppleWebKit/601.1.46 (KHTML, like Gecko) Version/9.0 Mobile/13G36 Safari/601.1”
We get an error on the iPad - see pic
Serbian flag is missing from language selection
Temperature for today pop up is not showing data, nor is any of the others. see pics
**** This appears to be intermittent since I’ve just checked it 4 hours later and there is graphs now!! ***
Today’s forecast( Friday 15th) is showing the wrong icon, should be the same icon as Saturday. It picked the right icon at 11:10am today
RFE…
Password should not be stored in cleartext in settings file, see…
http://php.net/manual/en/faq.passwords.php
Contact info popup should only show enabled methods i.e. don’t show twitter if account not configured.
Extras menu should only show configured options.
Extras menu items need config section in setup
When setting light theme, top bar stays dark.
the Fahrenheit indicator needs to move down a bit so it doesn’t crowd the menu on iPhone
Site loads tested on the following platforms …
Windows 7…
Firefox 60.5.1 ESR
Chrome 71.0.3578.98 (Official Build) (64-bit)
Linux RH7.6
Firefox 60.5.0 ESR
Chrome 3.0.3683.10 (Official Build) dev (64-bit)
iPhone 5S
iPhone OS 12_1_2 like Mac OS X) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/12.0 Mobile/15E148 Safari/604.1
ipad V2
iPad; CPU OS 9_3_5 like Mac OS X) AppleWebKit/601.1.46 (KHTML, like Gecko) Version/9.0 Mobile/13G36 Safari/601.1"
Nexus 7 tablet
Android 6.0.1 Chrome/70.0.3538.80
regards
Tim
@all beta-test
[ul][li]Please always check if the problem occurs at the pwsTEST/ site also. I can not upload a fresh beta test version every so many hours.[/li]
[li]I opened another topic just for the beta test, I will answer your beta-test-posts there
[/ul]
I think you misunderstood the definition of “beta” test or, English is not my native language, it was me who misunderstood it.
I can only assume that your current weather-website has all these errors already solved?
But when I checked, the same remarks are there also. It would be more polite to post “wishes” in the wish-list topic.
This WD34 April version includes 3 weather-alarms, WXSIM is back, Canadian text forecast are included and about 40% of the html errors are removed. And one former WD, now WC user, wanted to continue to use so the Cumulus/WC/Weewx users can now choose between 2 versions.
For every new release of this “WD” version, all user remarks will get sorted and according to my available time, they will be implemented.
Therefor, please try to help this programmer find the errors and omissions, do not waste my time with large lists of discussion points.
P.S. :oops: #-o :oops:
Sometimes my words sound to harsh. Sorry, So as an example, it took 4 hours to modify the contact-popup (bio-popup) .
It now hides twitter if there is no twitter-account (took approx. 5 minutes).
But it also has no html errors anymore, that took 80% of the time and as I hate unnecessary info, you can remove the links also from the pop-up and that plus testing took the remaining time.
https://validator.w3.org/nu/?doc=http://weather.skybase.net/pwsTEST/bio_popup.php => checking ends with fatal after 8 errors
https://validator.w3.org/nu/?doc=http://wd34.weather-template.com/pwsTEST/bio_popup.php no html errors
There are still numerous CSS errors but they will be removed in the June release.
Demo: the pwsTEST/ version has the links visible. The pwsWD/ version shows no links, still the areas are clickable.
Shouldn’t there be a facebook account added also?
bio_popup.php.zip (5.63 KB)
My appologies, I didn’t know about the “wishes” list - I will post future RFE’s there. :slight_smile:
Thats Ok, we all appreciate the effort you are doing to create this template and understand that it can be frustrating at times.
regards
Tim
Just a little off-topic :wink:
@TSL and all users of abbreviations in their posts
The WW forum caters for an international public with a lot of Dutch, Spanish, Italian, Korean a.s.o visitors.
Maybe English is “spoken” all over the world when one is on vacation, but please refrain from using abbreviations such as RFE as for over ?50%? of the forum visitors English is NOT their native language.
All those non-native speakers often use translate.google.com But that tool only knows that “RFE” is not English but it uses" Translate from: Haitian Creole" So when I read your post, I assumed it was a typo and ignored it, because my brain knows what it stands for. But my brain got it wrong, it was essential information and it seemed to mean for @TSL and maybe other native english speaking software professionals: “Request for Enhancements”
For me, as an older European person, it definitely stands for RadioFreeEurope, for immigrants to the US => Request For Evidence (RFE)
The other meanings for RFE => RFE - Wikipedia
A search for RFE on this forum yield 33 results of the rfe letters as (part of) a word in posts. Only the last one, the only one with the rfe as a separate word is this topic.
IMHO IWBW NTU abbreviations when we want to make our point.
keep up the good work Wim
we all appreciate your dedication :smiley:
My apologies again ! #-o
As for myself, I work for one of the top computer companies in the world with 135,000+ employees in over 300 countries and the term RFE ( Request for Enhancement ) has always been understood in any conversation I’ve had with anyone anywhere and is considered universal.
That being said … I shall refrain from using any abbreviations in future outside of the work environment in this forum :smiley:
regards
Tim
Something funny in the Nearby metar pop-up this morning. . . Is this a CheckWX problem?
Suddenly all metar pop-ups, old or new, show a date of 1-1-1970 UTC and an error message when error reporting is on.
And you are the first to notice it? Thanks :smiley:
First make a copy of the current script and please test this version,
P.S. “Is this a CheckWX problem” => yes
The date field in the json file now contains something more then the expected string:
"observed":"17-02-2019 <span class=\"tx-light tx-12\">@<\/span> 11:00Z",
metar_popup.php.zip (7.11 KB)
New version shows the wrong time: 00:20 am instead of 1120Z (UTC).
. . . and later 00:50 am instead of 1150Z.
Yes the invalid data is still there, so the time fields are more or less valid.
The “garbage in” results in “garbage out” for the time field, but without large error messages.
The unexpected values are still there, but shorter
"observed":"17-02-2019 @<\/span> 12:00Z"
Second beta version April release ready for download.
Read more at and download from http://wd34.weather-template.com/beta.php
Comments welcome at HWS-template (WD34) beta test topic
Do not update the beta releases, just remove old folder and test the new one from scratch, thanks
So there is nothing I can do about it?
i assume it will go away, but I modified the script a bit and see if this removes the extra unneeded characters.
metar_popup.php.zip (7.1 KB)
