Wim,
Still having issues with the popups. The csv files are getting populated, but the cron job does not appear to be erasing the data from the day before. https://www.weather911.net/pwsWD/
Also, getting spikes of data at 00:00 every day. Thanks.
Wim,
Only the daily csv files seems to be populated, others are empty, do not even exist yet: no 2019.csv or 2019_02.csv
I ran the add-to-year in the browser including error reporting:
…/pwsWD/_test.php?test=w34_cron_addtoyear.php
Warning: mysqli_connect(): (28000/1045): Access denied for user 'Jzinckgr'@'162.144.12.159' (using password: YES)
in /home4/jzinckgr/public_html/pwsWD/w34_cron_addtoyear.php on line 42
same for the clean script
in /home4/jzinckgr/public_html/pwsWD/w34_cron_empty.php on line 37
It seems that your easyweather settings are not correct. At least the midnight cron-jobs are not allowed to access your database.
The big question: are you sure that some script is adding data to your SQL table?
I think no script is doing that. Only two scripts can add data to the sql table.
WDapi which can run at set interval => it behaves like a cron-job also. Or the station-cron
The station-cron displays a message that it does not have to do that.
Your settings seems to be that the WDapi will do that.
But you are using clientraw.txt for your data, not WDapi as is shown in the footer of your page: Data Source: Clientraw C10.37S90
In easy weather, I have wdapi listed to upload the data. Is this correct? What about which option to use for “live data”? Clientraw or WD API?
NO. How does it work:
WeatherDisplay is uploading all kind of data to your website.
For use in the HWS-template you can chose between clientraw.txt and WDapi
=> You have selected clientraw.txt as is shown in the footer of your website page.
For the graphs you can select two sets of data which are not uploaded by WeatherDisplay
To generate the data yourself, you need a script which runs at a set interval.
a. You are NOT using the WDapi so it is not possible to use that one as WD will never start it
b. You use clientraw.txt so you have to use the station-cron-script.
Summary: You use clientraw for your data => WDapi is not possible => only station-cron is the one to use.
P.S. Probably station-cron will fail to load the sql-table as the other scripts accessing the database fail also.
After looking into this further, it appears my IP address is being blocked by spamhaus and is on the PBL list. Although this doens’t make sense since I can upload WD data to my server without problem. It’s just the mysql that is having issue.
Also, I can’t even get data tables to work with WU and I am using my station ID
You have to change your easyweathersettings from using SQL to using WU Then I can check what the problem is.
BUT: https://www.wunderground.com/weatherstation/WXDailyHistory.asp?ID=KMERAYM03&graphspan=day&year=&format=1
Returns no data, only the header line. You have a typo in your settings.
You typed KMERAYM03 but your WU station is KMERAYMO3 That will solve the WU-graphs
The Demo site now reflects a Canadian user. I try to test the new EC alert- and forecast-scripts.
Alert not very legible in Dark Theme, but OK in Light.
@ALL Testing is for me a two stage process.
First I use the light theme and try to get all PHP (script itself, unit conversion) and in-line css (scrolling a.s.o.) correct.
After that I look at how it works in different environments, on an Ipad, with the dark theme a.s.o.
So please post all the remarks but it can take some time before it is changed on the demo site.
Thanks for catching the station ID typo. Graphs working now, at least using WU. After Feb 15, who knows. Will have to get back to the sql table approach.
The WU graphs should continue to work after Feb 15th since they use the CSV download from the PWS page on WU, not the WU API.
They have said
We’d like to remind our PWS owners/contributors:Your past data will always be [b]available to you for viewing and download in a web browser on wunderground.com[/b], just as it always has. If you are in the small minority of people who use the WU API and a corresponding WU API key to obtain data in .json format, here's what's happening: We'll open a registration page for you to get a new API key to get your data in .json format You'll sign up and get a new API key for the new API Once the registration page is open, we'll keep the old API and your old API key active for 2 weeks to allow transition time to your new key
We’ll announce in the forum when the registration page opens.
Your past data will always be available to you for viewing and download in a web browser on wunderground.com, just as it always has.I tested, and when not logged-in with your account/password the download button does not appear and the adds show.
Can be a glitch, but I wait and see if they continue to allow access from a webserver.
I’m confused. I’ve been a Wu contributor for years and only have a station Id. Will I be grandfathered under the new rules? They say you’ll have access to historical data, but then say data will only be stored for the last 7 days. How does new data get historized if it’s deleted after 7 days?
Even if the download button is greyed out, the link in the script still works without login or cookies to get the CSV file with the data.
It’s been a unholy mess for WU as the IBM team attempts to dismantle the old WeatherUnderground API and substitute a newer weather.com API. A public relations AND a poorly planned/announced/developed conversion for the API.
The only scripts using the current WU API are for forecasts (WU-forecast.php and cousins). The graphing scripts rely on the CSV download from weatherunderground.com and (according to them) that is not changing in the future. IF someone was using the WU API for data (not forecasts), then those scripts will have to be changed, but AFAIK, the common scripts from Wim and I do not use the WU API for PWS data – only the WU website CSV downloads.
Thanks Ken. Interestingly, as soon as I started using the WU for my graphs, they stopped working after ~3hrs.
Somewhat off topic:
Their ‘forum’ is a mess also – a combination of a bad announcement, multiple rant-filled replies and calm responses by victoria from IBM and some shifting (over time) guidance about what will happen and especially WHEN. Originally, the announcement about the shutdown of the current WU API was done in mid-2018 for cutoff on Dec 31, 2018. It was revised to be 15-Feb-2019 as the ‘current’ date, but I strongly suspect that will also be moved as they are WAY BEHIND in offering the new API keys for the NEW API to anyone.
What is currently known:
My direct email questions to Victoria have been promptly and satisfactorily answered.
And yet that is how they say they will inform us of what happens next. I am not talking about “multiple rant-filled replies”, the link I posted is their latest statement.
So have mine. See http://discourse.weather-watch.com/
Opposite problem here in Edinburgh! DarkSky forecasts very high. . .
We do have a Met Office warning for high winds but here that means forecast gusts of 47 mph tonight/tomorrow morning. . . not 111/118 mph.
WU forecast (old version of w34, change /pws to /pwsold in home URL) added below.
Since I have been using the DarkSky forecasts I have noticed (in my area at least) the wind and to a lesser degree the rain forecasts have been somewhat unreliable.
I must say, I do prefer the WU forecasts, but understand the issues using this going forward.
Maybe there’s a problem with the script? I don’t see that kind of windspeed when I access the darksky website forecast for Edinburgh UK How Dark Sky users can use the Apple Weather app - Apple Support How Dark Sky users can use the Apple Weather app - Apple Support
As of now (3:34 AM GMT) I see Saturday wind forecast between 20 - 30 mph, and Sunday 10 - 20 mph
