Many thanks, Wim. (And niko!)
I got the impression it was longer than that. I’ll keep an eye on it.
That would imply that the oldest field of the 1 hour array would be reset to zero at midnight? As the calculation = oldest -/- latest
There had been no rain for 4.5 hours, so all fields should have been zero anyway. (Rain last hour had been showing zero, correctly, just before midnight.)
What is wrong [with API rain last hour]?
As above, there had been no rain for 4.5 hours. And screenshot was taken after midnight reset.
Are you running two versions? One for clientraw and 1 for WDapi?
I switch between them, using Menu/Settings, so I can spot any differences.
According to a doc from 2017: "43 0.0 rain total last 60 minutes"
My doc just says “43 raintotal60”. Doesn’t seem to be working here.
[Units] Attached
Many thanks.
I do not think the "low" values are in error. Maybe also others have an opinion about this, but for now I will put it on the wish-list as "add gust value to forecast".
Thanks for the explanation Wim - I was just trying to understand why the wind forecast always seemed to be rather low, and yes others may have an opinion on that.
I attach a test version of the 3 day forecast, as there is room to add the second value.
I have just updated to the the test version and it works fine. I will see how this goes over the next few days.
The 8 day forecast needs changes in the css, that is for later this year.
Thats fine - no real rush for this.
As always…thanks for your efforts.
Neil
Hi Wim,
I don’t think the Weather Alert window is correct. It shows a warning for the dew point below freezing. There’s a winter snow advisory out for our area. Is the exclamation point icon supposed to do anything when you click on it?
Mort
It is on the “wish-list” at *** closed*** HWS Template (WD34) Wish List to include real warnings from NOAA.
The three warning scripts (Europe/USA/Canada) are in Beta testing and will be included in the April release.
The current messages in the alert-box are based on your weather values, so “dew-point is below freezing” => icy road conditions.
The graphic warning sign “exclamation point icon” does nothing.
All ideas for enhancements please add them to the “wish-list”
Thanks, Wim.
Where do I get the path for the clientraw.txt from? In the settings screen it asks for path?
API[43] definitely not showing rain last 60 minutes, see APIrain4.
Rain today started 0430 and finished 0935, so it hadn’t rained for 8 hours when screenshot was taken. And there hasn’t been 1.6 mm rain in any one hour today.
So we have to ask Brian Hamilton what the meaning of that field is . I will dig into the documentation also.
This is the WDapi string as used by Brian.
=urlstring+'?d='+timestamp+'+'+tempdata+'+'+humdata+'+'+dewdata+'+'+winddata+'+'+gustdata+'+'+dirdata+'+'+rainratedata+'+'+raindata+'+'+barodata+'+'+dirdata+'+'+bftdata+'+--+'+barodata60+'+'+raindatamonth+'+'+raindatayear+'+'+raindatayesterday+'+'+intempdata+'+'+inhumdata
+'+'+chilldata+'+'+temp60data+'+'+dailymaxtempstr+'+'+maxtemptimestr+'+'+dailymintempstr+'+'+mintemptimestr+'+'+maxavspeedstr+'+'+maxspeedtimestr+'+'+maxspeedstr+'+'+maxgusttimestr+'+'+maxdailybaro+'+'+dailyhibarostr+'+'+mindailybaro
+'+'+dailylobarostr+'+'+mainunit.version+'+'+mainunit.version2+'+'+windmax10+'+--+--+'+uvdata+'+--+'+solardata+'+'+avtenwinddir+'+'+raintotal60+'+--+'+daynightflag+'+--+'+avtenwinddir+'+--+--+'+daylength+'+--+--+'+maxuvstr+'+'+maxdhum+'+'+maxdhumtime+'+'+mindhum+'+'+mindhumtime
+'+'+maxdaydew+'+'+maxddewtime+'+'+mindaydew+'+'+minddewtime+'+'+temp15data+'+'+hum15data+'+'+dew15data+'+'+indoortemp15data+'+'+indoorhum15data+'+'+extratemp1+'+'+extratemp2+'+'+extratemp3+'+'+extrahum1+'+'+extrahum2+'+'+extrahum3;
When one puts 1 field at a row
'+timestamp+'
+'+tempdata+'
+'+humdata+'
+'+dewdata+'
+'+winddata+'
+'+gustdata+'
+'+dirdata+'
+'+rainratedata+'
+'+raindata+'
+'+barodata+'
+'+dirdata+'
+'+bftdata+'
+'+barodata60+'
+'+raindatamonth+'
+'+raindatayear+'
+'+intempdata+'
+'+inhumdata+'
+'+chilldata+'
+'+temp60data+'
+'+maxtemptimestr+'
+'+mintemptimestr+'
+'+maxavspeedstr+'
+'+maxspeedstr+'
+'+maxgusttimestr+'
+'+maxdailybaro+'
+'+dailyhibarostr+'
+'+mindailybaro+'
+'+dailylobarostr+'
+'+windmax10+'
+'+uvdata+'
+'+solardata+'
+'+avtenwinddir+'
+'+raintotal60+'
+'+daynightflag+'
+'+avtenwinddir+'
+'+daylength+'
+'+maxuvstr+'
+'+maxdhum+'
+'+maxdhumtime+'
+'+mindhum+'
+'+mindhumtime+'
+'+maxdaydew+'
+'+maxddewtime+'
+'+mindaydew+'
+'+minddewtime+'
+'+temp15data+'
+'+hum15data+'
+'+dew15data+'
+'+extratemp1+'
+'+extratemp2+'
+'+extratemp3+'
+'+extrahum1+'
+'+extrahum2+'
+'+extrahum3;
First field has a space in it, so it counts as field[ 0 ] and [ 1 ] Field [ 43 ] has the label +raintotal60+
raintotal60 is the rain total 1 hour ago
I was provided with only what the custom tags names were from what meteohub was putting out and so it was not easy to try and figure out what everything should or should not have been
I had been experimenting with increased text size in Chrome browser settings and realised that it seems to affect the data-box outline size (not text size) in metar and earthquake pop-up windows too.
The metar attachment shows the result: metar2 is at default text size.
All boxes and locations are using pixel addressing. When you increase the text-size the text will not fit as the box will not grow.
Use the Chrome built in resize where you can enlarge the whole window, not only the text.
I have no English Chrome available now, it is in my dutch version the fourth menu entry where you can enlarge the total window, not only the text-size.
Attached image, left chrome in large size, right FF in normal size.
With both sizes the text fits.
Thanks, Wim, zoom function works well.
Trouble is, when one reaches a certain age one thinks that enlarging the text might be the generic answer to one’s viewing problems
Have you found the windows magnifier it my help
https://support.microsoft.com/en-us/help/11542/windows-use-magnifier
Wow! I don’t quite need that much, thanks!
It appears the tags being used in w34 for rain are incorrect for last hour rain. The monthly is also wrong but that is an issue with WD not correctly reporting data until the first day of a month is over…but the last hour rain as shown in the WD screen is correct. Is w34 able to access the Clientrawhour.txt file to grab info?
Weather forecast from Darksky is not working properly.
The API key is correct and I can see from my account page on their website that my installation is pulling the API about 80 - 100 times a day.
Still, the information shown is not up to date. See attached picture.
It is impossible to check what is happening when there is no link to the website.
There is one script to load all external data:
Fatal error: Uncaught Error: Call to undefined function curl_init() in /home/weather/public_html/w34_load_files.php:201
Stack trace: #0 /home/weather/public_html/w34_load_files.php(50): fnctn_load_file()
#1 /home/weather/public_html/_test.php(4): include('/home/weather/p...')
#2 {main} thrown in /home/weather/public_html/w34_load_files.php on line 201
Your own private PHP should support CURL to load the data from external sites.
I do not know which script is successfully accessing and using the DarkSky data 80-100 times a day.
All external accesses for “HWS-template for WD” should pass through this script.
For future problems you could make a info.php script available on your site. I attach this 1 line script,
info.php.zip (179 Bytes)
