Thank you, attached a new version of w34_livedata.php to solve this one.
The used clientraw.txt [143] is a logic field, it does not contain a value.
Thanks for testing. Attached the latest versions of yesterday and today.
When you find a problem, check with Leuven Home Weather Station (wf version) as I am testing also.
That demo-site runs most of the time for Edinburgh to make it “easier” for us to test both.
w34_frames.php
There are already two examples which do show in your menu.
Could you also check if the sr.png flag did arrive at the correct place.
That flag is missing from the menu. It should have been in the update zip you installed.
The websites may be too big to show in the frame. I’m playing with the length but it’ll need more width. And the Leuven template shows the Saratoga website for some reason:
$frame = 'website2';
$frm_ttls[$frame] = 'M82A1 Leuven site'; // name in menu
$frm_src[$frame] = 'http://www.m82a1.us/weather28/index.php?p=wsStartPage&lang=en';
$frm_hgth[$frame] = 2800; //height
It was not designed to put a large big site inside a one page only site. The original idea 4 or 5 years ago was to have a site which fits on an iPad nicely. With all weather-station information on one page.
The menu entries for extra pages are included as sometimes another page is needed for extra information which is not supported in the HWS-template. Example: a soil-sensors page. Or a specialised forecast.
You have to check your WU data, another glitch of WU/IBM
Last two lines in the file chartswudata/IEDINBUR98Y.txt are
2019-1-25,9.9,7.7,5.5,9.1,7.8,4.7,97,93,83,1007,1003,21,7,37,0.00 2019-1-26,9.5,8.9,8.4,8.5,7.6,6.2,95,90,84,1003,986,14,5,32,0.08
That data is loaded from WU. Not made by any script.
Maybe your settings at WU are misaligned for the timezone OR for the lat/lon???
No idea, Wim
