the web cam Q was asked and answered further up in this thread
Please always the URL to your pwsWD folder. I had to scan your previous posts to find the URL.
Yes, it is in the CSS and the three lines itself are centred. But the block with the three is not centred in the footer.
It only has a 75px left margin to not interfere with the images on the left.
As I have a longer third line it only looks like the block with the three lines is centred.
Adapting the CSS is a not so trivial task for the April release.
The previous post recommends: “You set the link to “…/webcam/image.jpg” which is 100% correct”
This is what I have done by specifying …/webcam/aad-axis-01.jpg , but on an “X weathercam” is shown in rectangle for Live Web Cam
ls -l webcam
total 156
-rw------- 1 weather weather 158374 Jan 17 09:26 aad-axis-01.jpg
After posting the previous message I discovered my error: owner user and group was incorrect.
Now it is working
It’s working now. Thank you
Hi Wim,
Sorry I have another question, this maybe a bug or a lack of understanding on my part. Currently I have an AQI reading on my site of 99 - this is based on the nearest AQ station (for me it’s Footscray, Australia). If I go to the link for this station the AQI is actually 35 - see link below.
I have then checked the output for my AQI in the module_test page, I can see the reference of an AQI of 35, but nothing for 99. How is the 99 generated? Maybe I am wrong, but I assumed my site should be showing the same AQI as the source, which is 35.
The link to my site is,
https://micklehamweather.com/pwsWD/
Neil
Thank you, added future code for test and did not remove all before release :oops: A new version is attached.
One can check the files itself by using this script: https://micklehamweather.com/pwsWD/w34_module_test.php
Just use list contents and select “./jsondata/gov_aqi.txt” it shows all data (also in json).
gov_aqi_block.php.zip (3.1 KB)
Thanks Wim - it
[quote author=Cheffy link=topic=67468.msg542463#msg542463 date=1547890244]
Thanks Wim - it
gov_aqi_popup.php.zip (6.91 KB)
Moon rise and set appear to be shown an hour late: moon set in Edinburgh this morning was 0645, next moon rise is 1425.
There is an update on-line with all changed scripts: http://wd34.weather-template.com/
The moon-block.php and two new supporting scripts in the other/ folder could take care of it.
Thanks also, please install the updates scripts from http://wd34.weather-template.com/
=> Updated scripts up to 2019-01-19 link http://wd34.weather-template.com/pwsWDupdate_2019-01-19.zip
Sorry, this is a first new version of the 2017 release and it needed people to test all those scripts in the last two weeks.
First clock I see not moving from left to right and back. =D> :thumbright:
Did you use another type of font for that?
That really looks good, great job Wim =D>
Yes any monotype font will do.
font-family: "Lucida Console", Monaco, monospace;
On request of a user as it was indeed irritating using a normal font, Wim
Great stuff, Wim! Special thanks for the clock. . . but Moon info pop-up rise/set still not right. See moon2 from http://swanston.maui.co.uk/pws/
P.S. _list.pdf has a few |2018-01-19| dates - should these be |2019-01-19|?
Hi Wim,
I got a “NO Boltek file found”.
https://www.weerstation-assen.nl/actueel-weer2.php
The Boltek file is there.
Thanks!
Brgds,
Oebel
To check what is happening, the URL to the pwsWD/ folder is essential. At home I can inspect and find it in the HTML. When traveling with an iPad no way. So this embedded / I Frame??? script will have to wait till tomorrow, sorry
The moon block is now OK. The pop-up was not touched yet, it is not on the list either. Need more time for that one.
