Wim’s quicker than I am with the parser! But I agree they all contain 0.3 mm. . .
[A single tip from my modified raingauge is actually 0.25 mm = 0.01 in, but WD doesn’t do mm to 2 d.p.]
To get the graphs to work using WU where do I set the API key, Do I place it in the dark weather section?
I see the station name for WU not a spot to add my API key.
Also moon rise moon set does not match WD using same lat/long
IMPORTANT
[/li]
[/ol]
So for now and at least until Feb 15, all graphs should work with your WU-station data. Just set the correct station-key usinge easyweather.
To check this out, I need the URL of your pwsWD/ folder.
And can you please post your latitude / longitude as you set in WD and in Easyweather? I con not check these myself as settings are protected from spying eyes.
Be aware that WeatherDisplay uses a minus for latitude east of Greenwich (f.i. Europe).
Other programs use the standard minus for west of Greenwich (f.i. the USA).
Also be aware that moon data can be confusing since the rise and set seen on one calendar day may be from two different moon cycles, see this recent thread.
its daily rain total
as per the clientrawdescription.txt
i.e so its the daily rain total 60 minutes ago
then the daily rain total 59 minutes ago
etc
clientraw.txt does have
100-109 array of last rain last hour (10 positions)
and that too is daily rain total at those times
My AQI is reading “offline”. Is this normal between data updates?
The date-time seemed to be in “UTC” for other test-sites. Now it is in local as far as i can see.
Try this script for a few days, I changed only line 93 from gmdate() to date()
As the time difference here in wester Europe between UTC and local is small, this error was not found when testing.
PM or mail me if there are still problems.
P.S. better version attached at 15:21 UTC
gov_aqi_block.php.zip (3.09 KB)
Thanks, also for the mail.
The array [100] → [109] covers only 1 hour divided in 10 data points.
“total rain of the last hour” = latest data point [100] minus oldest point [109];
w34_livedata.php line 132 is changed from
$weather["rain_lasthour"] = convert_precip ($wd[100],$from,$to);
to
$value = (float) $wd[100] - (float) $wd[109]; # 2019-01-14
$weather["rain_lasthour"] = convert_precip ($value ,$from,$to); # 2019-01-14
w34_livedata.php.zip (5.4 KB)
I have had this version up and running for the last few days now, however I can’t seem to get the graphs working. I have set up the WD API and tested with success and I have set up the SQL table and I can see the data arriving every minute, however I can’t seem to generate the graphs. The ‘Today’ graph seems to be populated with some demo data and does not seem to change. Am I missing something?
I can switch the source of the graph data from WU and that works fine.
Is there any ideas what I am doing wrong?
The link to my site is,
http://micklehamweather.com/pwsWD/
Neil
I can not check your settings, so I attach a screenshot. How did you set these two settings?
It works like this:
If all database settings are OK:
WDapi or the stationcron will store 1 record in the database
If charts are set to Database
=> stationcron will store one line in results.csv
In hindsight, it is more logical to let WD-api add the lines to the .csv when it is loading the DB-record.
But that file can grow very rapidly when the upload interval is set to frequently.
Just before and after midnight the two other cron-scripts will add 1 line to year and monh csv files and clean todays data from the database.
The result.csv (= this days data) is then cleared also.
As far as I can see, based on the file-contents, you set WDapi to upload to the database, but are not running a cron-job.
P.S. I added another post below about the sun-block
I do not understand the sun block on your site.
These should be the settings (for Melbourne) in pwsWD/w34_settings1.php. Could you check them?
$TZ = "Australia/Melbourne";
$lat = (float) "-37.813611";
$lon = (float) "144.963056";
I attach the latest version of the script, for easier reference it displays the hours around the 24-hr clock.
You have to add the azimuth script also.
At noon there should be sun, at midnight it should be dark.
sun_block.php.zip (2.94 KB)
azimuth.php.zip (3.64 KB)
Yes, stupid me. I wanted to check how the beta-sun script would work in Australia.
I forgot that others could also download that script. Will do it with PM’s from now on.
For the new sun script you need the Niko’s version of the Azimuth/elevation script also, it is attached.
Succes, PM me if you have more problems with this version.
No worries, sun/azimuth working now! And so is the rain last hour, I think: I’ll check that when we get more rain
Thanks Wim.
I checked my settings and you were correct I had set WDapi to upload to the database, I have now changed it to ‘stationcron job will the database load’ - however I am still having issues.
I think I understand how it works now, I originally had WDapi to upload to the database and I could see the data coming into my SQL table on 1 minute intervals (but obviously not populating the .csv files). Since I have changed to the cronjob load option, nothing is coming into my SQL table. It seems like the cronjobs in WD are not running. If I manually run the following link, it will work but nothing is happening in WD.
http://micklehamweather.com/pwsWD/w34_cron_stationcron.php
I have checked and double checked the links in WD but I can’t seem to work it out why it won’t work. I have included some of my settings, maybe I have missed something!
Re the sun block on my site, I have checked my settings and they match what you had suggested so again I am not sure what has happened there!
I have attached a copy of what I can currently see.
Thanks again for your help with this.
Neil
The WDapi works fine, so you can set that to upload the SQL table.
I agree that it seems the cron-jobs are not running as they should. They run OK when manually started. But they do not appear to be run by WD.
Please check first if there are no spaces or other strange characters before or after the cron links.
If all seems OK on your end, contact Brian Hamilton maybe he can see in the logs what the problem is.
Re the sun block on my site, I have checked my settings and they match what you had suggested so again I am not sure what has happened there! I have attached a copy of what I can currently see. Thanks again for your help with this. NeilThe problem with the sun-block is not something you can see. Only visitors from another timezone see a strange circle. Attached a screenshot hot is looks when I visit your site
Thanks Wim - all good now, I have it working!
The issue was a leading blank space at the start!! It was hard to spot - but now that I have noticed it, it’s quite obvious…sorry! :oops:
Neil
Hi Neil,
Thank you! I had same problem and could not find it.
Solved!
Brgds,
Oebel
