Thanks…if I already owned carp I would try it, but I don’t…
Helo Wim
Noticed the wind data refresh is about 30 seconds. How can i decrease the clientraw refresh interval?
Is that not set in WD?
Also when i click on nearby on current conditions i get lots of warning messages...
Working OK here for EGFF.
Thanks Bitsostring
Just checked the local and now working???
Strange.
In the old weather 34 software there was an option to alter the refresh rate. Wait for Wim to see the question
There is a setting, BUT it is not user configurable.
Be aware that playing around with reload settings will increase the load of you server.
http://wd34.weather-template.com/pwsWD/w34_module_test.php => test wind_gust_block.php
wind_gust_block.php (25) include_once =>w34_livedata.php => loads the clientraw or WDapi data
w34_livedata.php (28) include_once =>w34_settings.php
w34_settings.php (31) include =>w34_settings1.php
w34_livedata.php (32) include_once =>w34_shared.php => loads convert functions and multiple SVG icons
wind_gust_block.php (29) include_once =>w34_common.php => loads the language file
All other blocks are loaded in the same way and have to load all those supporting scripts/files also
All this to get the “realtime” data in the correct unit and the words translated to the correct language
So if you have a normal hosting account do not set the refresh-times to short.
I will move the default refresh-times settings to easyweather in April.
For now check the w34_blocks.php which contains the headings, pop-ups and refresh-time for each block used.
I assume my server php version is the problem…but this doesn’t appear to affect anything…yet. Should I be concerned?
[i]Warning: date(): It is not safe to rely on the system’s timezone settings. You are required to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone ‘UTC’ for now, but please set date.timezone to select your timezone. in /home/trave147/public_html/pwsWD/w34_easyweathersetup.php on line 106
weather34 EASY SETUP for WeatherDisplay
Back to the main page
Enter your password for the “Setup Screen” below
Info: Your current PHP version is : 5.5.38
PHP 7+ is advised for this template but it will run also with PHP 5.6.3 or higher[/i]
Thanks, I will remove that one also in the April version.
Just checked the conversion factor for my old w34 (V.3.4-X5(d)) page too: it was showing 110.6 mi instead of 59.8!
In the alerts.weather.gov version, would it be possible to have the ability to add multiple codes i.e. CAZ095 (Kern County Mountains) and CAC029 (Kern County) which is roughly the same area except the zone code CAZ095 could take in a larger area and parts of several counties? The reason being able to add multiple codes is that the NWS could issue an alert either for the zone or county depending on the type of alert and affected area. Another good example of this is in Kansas where the counties and zones are the same area.
Current Watches, Warnings and Advisories for Wyandotte (KSZ104) Kansas Issued by the National Weather Service (Wyandotte)
Current Watches, Warnings and Advisories for Wyandotte (KSC209) Kansas Issued by the National Weather Service (Wyandotte)
Hello Wim
Trying to add my links on the extras field.
I have added one of my own but nothing is appearing.The other links that were there are working ok.
Can you see any issue with the data i have entered ?
these are examples, please use your own ones
$frame = ‘Latest North Atlantic Synoptic Chart’;
$frm_ttls[$frame] = lang(‘Latest North Atlantic Synoptic Chart’); // name in menu
$frm_src[$frame] = ‘https://ocean.weather.gov/A_sfc_full_ocean_color.png’.$used_lang;
$frm_hgth[$frame] = 946; // name in menu
$frame = ‘BNLWN_mesonet’;
$frm_ttls[$frame] = lang(‘Benelux Weather Network’); // name in menu
$frm_src[$frame] = ‘http://www.beneluxweather.net/mesonet-map/mesonet-map.php?lang=’.$used_lang;
$frm_hgth[$frame] = 1366; // name in menu
$frame = ‘EWN_mesonet’;
$frm_ttls[$frame] = lang(‘European Weather Network’); // name in menu
$frm_src[$frame] = ‘https://www.weerstation-herent.be/ewn/stations.php?lang=’.$used_lang;
$frm_hgth[$frame] = 1500; // name in menu
Steve
Change the link to:
$frm_src[$frame] = 'https://ocean.weather.gov/A_sfc_full_ocean_color.png';
But even then it will not display, check in your browser: right-click => inspect => console
Refused to display ‘https://ocean.weather.gov/A_sfc_full_ocean_color.png’ in a frame because it set ‘X-Frame-Options’ to ‘sameorigin’
So you are not allowed to display those images in an iframe.
More and more websites do that as they do not want their content “copied”
Ok Wim thanks
Bit of a bummer but thanks for trying for me
Steve
I changed the scripts to also include plain images without an iframe.
Attached zip, replace two scripts but do not forget to make a copy of the current scripts first.
You can check the result at http://wd34.weather-template.com/pwsWD/w34_start_frame.php?frame=TEST
frames.zip (5.86 KB)
Ok Wim did what you said and looking good.
Any idea why the W34 part of my website won’t show on my ipad?
Getting message …Error: Embedded data could not be displayed.
Think it’s the code on my site. Not good at all with this stuff
Ps all shows ok on my laptop
steve
Google is your best friend => “Embed tag was never endorsed by the W3C so it’s invalid code, although some browsers support it.”
Safari is the engine on the iPad and more strict than others. Chrome on the iPad uses the Safari engine also.
When you redo your site with iframe it will work on all platforms.
Ok Wim Thanks
Will research it and try
Hello Wim
Thx for the update of this nice layout.
I have it up and go, but i se on the right side on the current condition and push the link on “nearby” i get (EEBR , Brussel)
Did you het your METAR API key?
Ahhhhh sorry Wim, it’s on place i forgot to do that. Thx
