Wim, why is the data from both the Davies Instruments and WeatherFlow weather stations being processed in this newer version of the ‘weather34’ templates - should it not be either the data from the Davies Instruments weather stations (ie: Weather Display - clientraw.txt/WDapi.txt) or the data from the WeatherFlow weather station (ie: WeatherFlow API - weatherflow.txt).
From what I can see so far (looking through the different scripts), the ‘weather34’ templates appear to use mostly the data from Weather Display (ie: clientraw.txt/WDapi.txt).
I understand that most users only have one weather station. Would it not be better/simpler if the data used was from only one provider (ie: Weather Display or WeatherFlow).
Just curious… :?
Wim, may I make a suggestion - when replying to a message could you either not quote the whole message or only quote the part of the message you are replying to - otherwise the message thread very long very quick.
A weatherwebsite can have multiple extra sensors, f.i. AirQuality sensor => supported Luftdaten, Purpleair and official, a lightning-sensor => supported Nextstorm and WeatherFlow. Same as for current conditions, supported WD, Metar or Darksky.
In this version of weather34, the WeatherFlow measurements used are only the lightning ones. No other values.
And UV/solar for those stations who are missing an UV / Solar-sensor.
There is als a weather34 version for Weatherflow where almost all data comes from Weatherflow.
The 2017 version for WD also used some WF values, at least the version I had to start with making this new one from.
Also nobody has to use the weatherflow. All extra sensors arte optional.
Same for forecasts. As soon as the new WU-api is available one can choose between DarkSky or WU again for forecasts.
As > 90% of my post are answers to questions or other posts I burned myself a few times by not quoting completely.
Some persons change their original quote AFTER they get an answer so that the answer is not valid anymore.
That is why I try to include their complete original text, to make sure that my answers make sense, even after the original post is changed or removed.
Hello Wim,
checking the template missing put:
in w34_easyweathersetup.php
the catalan language
line 225
original: | 02 | - | - | flag | select | en | en # English! nl # Dutch! fr # French! de # German! it # Italian! sp # Spain |
modified:
| 02 | - | - | flag | select | en | en # English! Nl # Dutch! Fr # French! De # German! It # Italian! Sp # Spain! Ct # Catalan |
and so that the flag comes out at the end of the sript
ask for a flag: img / flags / ct.svg
is not, you would have to add or modify the script to call ct.svg
Thank you
Emilio
It is already in the downloads since yesterday on http://wd34.weather-template.com/ Additional/changed scripts to support the Italian, Spanish and Catalan language. Thank you Daniel and Emilio
Before posting the update I installed at the demo site, it looks catalan to me, the flag looks different, so i assume it is working. Leuven Home Weather Station (wf version)
Please check again and e-mail me if there are problems.
:oops: I misunderstood, thought you referred to the flag in the menu. Thanks for spotting the error.
I adapt the easyweathersetup and upload a new version.
Wim, the weather34 template is really a nice piece of work. Kudos to you and the team for creating it. I have mine setup and working but, for some reason, I am not getting the current forecast. What could I be missing? Also, where are the current weather alerts supposed to come from? Right now, we have a Wind Advisory posted for our area and there is no alert in the Weather Alert box.
100% BrianUnderdown (weather34) for the design and original scripts. I myself are your humble servant to do the support for this version
You have to apply for a DarkSky api key and enter it in easyweathersetup. Nearly at the bottom
Also, where are the current weather alerts supposed to come from? Right now, we have a Wind Advisory posted for our area and there is no alert in the Weather Alert box. http://ucweather.org/pwsWD/
The weather alerts come from the weather-values in the scripts themselves. Not from an outside company as NWS or Meteoalarm.
Thanks a lot, Wim. Working great now, even got a weather alert. Should be interesting to watch the next several days as we are supposed to get a lot of wind and rain. BTW, I really like the air quality sensor feature.
You should unzip the update.
The 10 changed scripts go into the pwsWD/ folder on your server.
There are two folders with a name "copy to "
One has the extra flag, goes into pwdWD/img/flags/ The other has the extra language files for pwdWD/languages/
Very easy solution:
Correct all typing errors by using the language files. |'Select langauge|Select language|
That way you are sure that with a new release the error does not return.
And that visitors using another language can see the translation to their language also.
The script-editors do not catch those typing errors and English is not my native language either
This: |from text in script |to text visitor sees| is therefor used by multiple template authors.
And the words “Template by weather34.com” at bottom right overhang the main template “frame”. . .?
Can you make a small screenshot, as I do not understand what the problem is at my test site, thanks.
