Thanks Wim…working now :wink:
windrun is in KM in the clientraw data, sorry about that confusion
Wim, you should include a donate button for all your help/time?
Hello,
my programming skills are scarce
I changed in the script:
barometer_block.php
the next line for the translation to take place
line 53
echo ‘Trend’;
by
echo ‘’ .lang (‘Trend’). ’
any opinion
regards
#-o #-o
Wim, using the WeatherFlow REST API, the ‘latest station observation’ data that is returned for my station is as follow (as of 11:15 PST):
outdoor_keys": [
    "timestamp",
    "air_temperature",
    "barometric_pressure",
    "station_pressure",
    "sea_level_pressure",
    "relative_humidity",
    "precip",
    "precip_accum_last_1hr",
    "precip_accum_last_24hr",
    "precip_accum_local_day",
    "precip_accum_local_yesterday",
    "wind_avg",
    "wind_direction",
    "wind_gust",
    "wind_lull",
    "solar_radiation",
    "uv",
    "brightness",
    "lightning_strike_count",
    "lightning_strike_count_last_3hr",
    "feels_like",
    "heat_index",
    "wind_chill",
    "dew_point",
    "wet_bulb_temperature",
    "delta_t",
    "air_density"
But then, looking at the ‘latest station observation’ for another station, the data that is returned is:
outdoor_keys": [
    "timestamp",
    "air_temperature",
    "station_pressure",
    "precip",
    "wind_avg",
    "wind_direction",
    "wind_gust",
    "wind_lull",
    "solar_radiation",
    "uv",
    "brightness",
    "lightning_strike_last_epoch",
    "lightning_strike_last_distance",
    "feels_like",
    "heat_index",
    "wind_chill",
    "dew_point",
    "delta_t",
    "air_density"
Both station have the same firmware: ‘firmware_revision": “103”’
I have no idea why the returned data would be different from one station and another! :?
Good catch,
I tried to find all untranslated words, but they hide very well. And a lot of English and Dutch words are the exactly the same in spelling, albeit not always in the meaning.
So I changed this one in the scripts also from
echo 'Trend';
to
echo lang('Trend');
No need to add those . as those are only used to concatenate strings.
The logical explanation is that the stations without any lightning in the past, can not have a date of the last lightning, nor a distance of the last lightning. They therefor will not output those two extra fields.
“lightning_strike_last_epoch”, “lightning_strike_last_distance”,
Wim, why is the data from both the Davies Instruments and WeatherFlow weather stations being processed in this newer version of the ‘weather34’ templates - should it not be either the data from the Davies Instruments weather stations (ie: Weather Display - clientraw.txt/WDapi.txt) or the data from the WeatherFlow weather station (ie: WeatherFlow API - weatherflow.txt).
From what I can see so far (looking through the different scripts), the ‘weather34’ templates appear to use mostly the data from Weather Display (ie: clientraw.txt/WDapi.txt).
I understand that most users only have one weather station. Would it not be better/simpler if the data used was from only one provider (ie: Weather Display or WeatherFlow).
Just curious… :?
Wim, may I make a suggestion - when replying to a message could you either not quote the whole message or only quote the part of the message you are replying to - otherwise the message thread very long very quick. :wink:
A weatherwebsite can have multiple extra sensors, f.i. AirQuality sensor => supported Luftdaten, Purpleair and official, a lightning-sensor => supported Nextstorm and WeatherFlow. Same as for current conditions, supported WD, Metar or Darksky.
In this version of weather34, the WeatherFlow measurements used are only the lightning ones. No other values.
And UV/solar for those stations who are missing an UV / Solar-sensor.
There is als a weather34 version for Weatherflow where almost all data comes from Weatherflow.
The 2017 version for WD also used some WF values, at least the version I had to start with making this new one from.
Also nobody has to use the weatherflow. All extra sensors arte optional.
Same for forecasts. As soon as the new WU-api is available one can choose between DarkSky or WU again for forecasts.
As > 90% of my post are answers to questions or other posts I burned myself a few times by not quoting completely.
Some persons change their original quote AFTER they get an answer so that the answer is not valid anymore.
That is why I try to include their complete original text, to make sure that my answers make sense, even after the original post is changed or removed.
Hello Wim,
checking the template missing put:
in w34_easyweathersetup.php
the catalan language
line 225
original: | 02 | - | - | flag | select | en | en # English! nl # Dutch! fr # French! de # German! it # Italian! sp # Spain |
modified:
| 02 | - | - | flag | select | en | en # English! Nl # Dutch! Fr # French! De # German! It # Italian! Sp # Spain! Ct # Catalan |
and so that the flag comes out at the end of the sript
ask for a flag: img / flags / ct.svg
is not, you would have to add or modify the script to call ct.svg
Thank you
Emilio
It is already in the downloads since yesterday on http://wd34.weather-template.com/
Additional/changed scripts to support the Italian, Spanish and Catalan language. Thank you Daniel and Emilio
Before posting the update I installed at the demo site, it looks catalan to me, the flag looks different, so i assume it is working. Leuven Home Weather Station (wf version)
Please check again and e-mail me if there are problems.
I attach two images of the problem
the first image is with the modified sript so that it comes out catalan
:oops: I misunderstood, thought you referred to the flag in the menu. Thanks for spotting the error.
I adapt the easyweathersetup and upload a new version.
I think that light breeze should be 2 Bft not 6 Bft :?
Yes, it should be 6 Kts or 2 Bft or both.
Will check if there is enough space for both.OK at Leuven Home Weather Station (wf version)
wind_gust_block.php.zip (3.54 KB)
Did we have a definitive answer to the windrun problem yet? Apologies if I’ve missed it.
Just try the block from #66 above.
It should work OK, but as changes, it needs a few days testing.
I think that is now OK. Maybe you could at the same time make a change for Wind run for scandinavia meters and wind block.
In settings I set DarkSky forecast language English but on main page I have Dutch language (I set default Duch language in Settings).
Is already in the lates update download. Always check at Leuven Home Weather Station (wf version)
Darksky has its own language setting! Nearly at the bottom where the API key is entered. You can select Serbian also there.
Wim, the weather34 template is really a nice piece of work. Kudos to you and the team for creating it. I have mine setup and working but, for some reason, I am not getting the current forecast. What could I be missing? Also, where are the current weather alerts supposed to come from? Right now, we have a Wind Advisory posted for our area and there is no alert in the Weather Alert box.
http://ucweather.org/pwsWD/
100% BrianUnderdown (weather34) for the design and original scripts. I myself are your humble servant to do the support for this version
You have to apply for a DarkSky api key and enter it in easyweathersetup. Nearly at the bottom
The weather alerts come from the weather-values in the scripts themselves. Not from an outside company as NWS or Meteoalarm.
