Author Topic: ***closed*** weather34 for WeatherDisplay (clientraw and WDapi)  (Read 24710 times)
0 Members and 3 Guests are viewing this topic.
Offline wvdkuil
  • Wim van der Kuil
  • Leuven Belgium CET
  • Mac OS X 10.13.6
  • Chrome 71.0.3578.98
« on: January 01, 2019, 09:36:24 AM »
There  has been other discussions about support for WeatherDisplay in the "weather34" template as designed and developed by BrianUnderdown.
BrianUnderdown now fully supports the Meteobridge version at his template-site.
You can check there (scroll down to Notice Please Read) which other versions are supported by which person and where to find those versions.
As from today,  the first release of "weather34 version for WeatherDisplay" is available for download at  http://wd34.weather-template.com/index.php
  • This version supports FTP-upload of clientraw.txt and HTTP-upload using the WDapi.
  • The current conditions can be from WD-clientraw, DarkSky (needs an API-key) or METAR  (needs an API-key).
  • Forecast data only from DarkSky (+API-key)  for this version, probably wxsim and met.no will be available in the next release
  • Next release (April) will also use the latest css I just received from Brian Underdown
  • Graphs can be generated from your WU-data or from a SQL-table which is relative easy to setup
Please use this  post for comments and questions for the WD-version so we keep them separated from the discussions about the other versions.
« Last Edit: July 12, 2019, 01:18:03 PM by wvdkuil »
Offline NorCal Dan
  • Dan - KJ6RGX
  • Davis Vue/Win10
  • Ocean Park, WA.
  • Mac OS X 10.10.5
    • Traveling RV Weather
« Reply #1 on: January 01, 2019, 04:50:48 PM »
Very nice Wim...excellent work... :wink:
http://travelingrvwx.com/pwsWD/
« Last Edit: January 01, 2019, 06:24:13 PM by NorCal Dan »
Offline niko
  • syzygy
  • Northern California, U.S.A.
  • Win 7/Srvr 2008R2
« Reply #2 on: January 01, 2019, 04:53:29 PM »
Yes, nice work Wim! It's very good to see this option actively supported again  :D
  • Davis VP2
    • Weather Display
« Reply #3 on: January 01, 2019, 05:29:46 PM »
Great work Wim :)
Offline carseman
  • Carse of Gowrie, Tayside, Scotland, UK
  • Mozilla compatible
    • Carseweather
« Reply #4 on: January 01, 2019, 07:04:15 PM »
Wim,
Working here - thanks for your hard work.
https://carseweather.uk
However…. I do not see an entry in Weather Display control panel for the home weather station API . My version of WD is 10.37 B85, dated  27/12/18 - Brian can you please shed light on this?
Chris
  • Davis VP2
    • Weather Display
« Reply #5 on: January 01, 2019, 07:09:21 PM »
you just need to create a file (for now) called homeweatheron.txt
where WD is installed
Wim must have that mentioned somewhere I am sure
« Last Edit: January 01, 2019, 07:20:41 PM by Weather Display »
Offline carseman
    • Carseweather
« Reply #6 on: January 01, 2019, 07:16:55 PM »
Brian,
Thanks - I should have RFTM.   :oops: :oops: :oops:    I will have play later.
Chris
Offline eb3bvb
  • Torrelavega, Cantabria
  • Firefox 64.0
    • meteotorrelavega
« Reply #7 on: January 01, 2019, 09:27:51 PM »
I do not see the W34 logo in the WD version 10,37s85
what to do
Thank you
Offline carseman
    • Carseweather
« Reply #8 on: January 01, 2019, 09:33:33 PM »
see Brian's reply  above
Chris
Offline johnmac78
  • Westminster, Massachusetts USA
  • Win 7/Srvr 2008R2
    • Village at Old Mill - Weather
« Reply #9 on: January 02, 2019, 12:51:55 AM »
Having an issue setting up my webcam with Weather 34 for Weather Display.
Weather 34 is in the pwsWD directory (Public_html/pwsWD/)
The webcam is at (public_html/webcam/image.jpg) in the settings page I have tried all the following - (./webcam/image.jpg )  (../webcam/image.jpg)  I also tried adding the public_html/webcam/image.html.
Any suggestions would be greatly appreciated.
Thank you, John
John
scannorthcounty.net
Offline NorCal Dan
  • Dan - KJ6RGX
  • Davis Vue/Win10
  • Ocean Park, WA.
  • Mac OS X 10.10.5
« Reply #10 on: January 02, 2019, 02:29:28 AM »
$webcam_img     =  '../webcam/jpgwebcam.jpg';
Works for me here...
Offline wvdkuil
  • Wim van der Kuil
  • Mac OS X 10.13.6
« Reply #11 on: January 02, 2019, 07:47:28 AM »
Thank you, John
Sorry, I did not write it clear enough in the settings script.
You set the link to  "../webcam/image.jpg" which is 100% correct
The scripts add a timestamp to the static image link to bypass old images in the browser cache.
If you change it in the settings to "../webcam/image.jpg?" (so add an ? to the link) it will function as it should.
Offline eb3bvb
  • Firefox 64.0
    • meteotorrelavega
« Reply #12 on: January 02, 2019, 09:13:24 AM »
This is normal, to do the translation
is in lang_extra.txt
# days
                             |Fri |Fri |
                              |Mon|Mon|
                             |Mon |Mon
                             |Sat |Sat |
                             |Sun |Sun |
                            |Thur |Thur |
                             |Tue |Tue |
                             |Wed |Wed |
Offline wvdkuil
  • Wim van der Kuil
  • Mac OS X 10.13.6
« Reply #13 on: January 02, 2019, 09:31:41 AM »
# days
                             |Fri |Fri |
                              |Mon|Mon|
                             |Mon |Mon
                             |Sat |Sat |
                             |Sun |Sun |
                            |Thur |Thur |
                             |Tue |Tue |
                             |Wed |Wed |
The re are a lot of scripts with a lot of words which should be translated
If you want to make your own translation, as an example to Spanish, translate only the right part.
So
Code: [Select]
                              |Mon|Lun|
                             |Mon |Lun |
If that is not your question, please clarify what you want to ask.  Leave a space in the translation as that is probably needed to keep the words apart.
Offline meteosa
  • Italy
  • Win 7/Srvr 2008R2
  • Firefox 64.0
    • MeteoSantAngelo.it
« Reply #14 on: January 02, 2019, 11:43:03 AM »
Hi everyone,
in the guide is written to set to WD "Home weather station" in Control Panel, but I do not have it, I have the latest version installed, why?
I am attaching the image
Thank you
