Author Topic: weather34 for WeatherDisplay (clientraw and WDapi)  (Read 15608 times)
Offline zitterbacke
  • iOS 12.1.4
  • Safari 12.0
Re: weather34 for WeatherDisplay (clientraw and WDapi)
« Reply #315 on: February 10, 2019, 05:43:16 PM »
Hi Wim,
Thanks a lot for the Weather Display version of the HWS Template. I don’t use it with Weather Display but with Meteohub and it works very well and I really like it. One minor issue I have noticed so far, my country flag isn‘t displayed in the footer, but only an empty box is shown there. How can I fix it?
Here‘s the link to my Testing-Page.
https://jensilein65.bplaced.net/pwsWD/
Best regards, Jens
Offline wvdkuil
  • Wim van der Kuil
  • Leuven Belgium CET
  • Mac OS X 10.13.6
  • Chrome 71.0.3578.98
    • My PWS at Leuven Belgium Europe
« Reply #316 on: February 10, 2019, 05:48:57 PM »
Hi Wim,
Best regards, Jens
The fastest way to solve this problem is to copy the  ../img/flags/dl.svg  and give the copy the correct name .. /img/flags/de.svg
IMPORTANT:  Visit: http://wd34.weather-template.com/
And install the updates , just 2 lines below the full download "Updated scripts up to 2019-01-19 plus 4 additional languages."
Success, Wim
« Last Edit: February 10, 2019, 05:53:18 PM by wvdkuil »
Offline zitterbacke
  • iOS 12.1.4
  • Safari 12.0
« Reply #317 on: February 10, 2019, 05:54:39 PM »
Perfect, now the flag is shown correctly  :D
Offline zitterbacke
  • iOS 12.1.4
  • Safari 12.0
« Reply #318 on: February 10, 2019, 05:58:28 PM »
Wim, another short question. In the temperature block (using German language setting) there is shown the term „Feuchtkugel“. What does that mean?
Jens
Offline bitsostring
  • Oregon Scientific WMR200
  • Edinburgh, U.K.
  • Win NT 10.0
  • Chrome 64.0.3282.140
    • Home Weather Station
« Reply #319 on: February 10, 2019, 06:16:03 PM »
That position in the temperature block is showing "Wet-bulb temperature", if that helps.
« Last Edit: February 10, 2019, 10:28:37 PM by bitsostring »
It's meant to be fun. . .
Offline zitterbacke
  • iOS 12.1.4
  • Safari 12.0
« Reply #320 on: February 10, 2019, 06:16:50 PM »
OK, got it. Can you plz help me with another issue. In the block Sun Moon & Space the text block within the circle is not centered and exceeds the circle respectively, at least with German language setting. Where can I fix that? I would assume in the sun_block.php, but where exactly and how?
Jens
« Last Edit: February 10, 2019, 06:19:07 PM by zitterbacke »
Offline bitsostring
  • Edinburgh, U.K.
  • Win NT 10.0
« Reply #321 on: February 10, 2019, 06:49:47 PM »
Probably in the language file, but Wim can answer your question definitively. I am just another user  :)
« Last Edit: February 10, 2019, 08:16:29 PM by bitsostring »
Offline zitterbacke
  • Win NT 10.0
  • Firefox 65.0
« Reply #322 on: February 10, 2019, 08:36:54 PM »
Hi Wim,
can you please help me with following two issues. In the block Sun Moon & Space the text block within the circle is not centered and exceeds the circle, at least with German language setting ("Bis zum Sonnenuntergang"). Where can I fix that? The second thing is regarding the monthly and yearly temperature charts. The two graphs that are shown there are named with "High" and "Niedrige Solar Radiation". The term "Niedrige Solar Radiation" doesn't fit here, maybe it has to be "Minimum Temperatur" and "High" should better be named as "Maximum Temperatur". Where can I fix it?
Jens
Offline niko
  • syzygy
  • Global Moderator
  • Northern California, U.S.A.
  • Win 7/Srvr 2008R2
« Reply #323 on: February 10, 2019, 08:56:08 PM »
The translations are in languages\lang_de.txt
Offline zitterbacke
  • iOS 12.1.4
  • Safari 12.0
« Reply #324 on: February 10, 2019, 09:12:19 PM »
I didn‘t find these terms in there...
Offline bitsostring
  • Edinburgh, U.K.
  • Win NT 10.0
« Reply #325 on: February 10, 2019, 09:23:39 PM »
Try these, from lang_de.txt:
|Till Sunrise|Bis zum Sonnenaufgang|
|Till Sunset|Bis zum Sonnenuntergang|
Maybe you can abbreviate the German to fit?
« Last Edit: February 10, 2019, 09:25:56 PM by bitsostring »
Offline zitterbacke
  • iOS 12.1.4
  • Safari 12.0
« Reply #326 on: February 10, 2019, 09:42:07 PM »
Thanks, I will try it. Do you also have an idea where to find the terms that are used in the temperature charts?
Offline bitsostring
  • Edinburgh, U.K.
  • Win NT 10.0
« Reply #327 on: February 10, 2019, 09:51:58 PM »
No, sorry. Actually, yes:
|Low|Niedrige Solar<br><color>Radiation</color>|
appears in lang_de.txt as well, but I advise you to wait for Wim to reply before you tackle this one, it's not in the right place!
« Last Edit: February 11, 2019, 07:13:24 PM by bitsostring »
Offline niko
  • syzygy
  • Global Moderator
  • Win 7/Srvr 2008R2
« Reply #328 on: February 10, 2019, 10:05:21 PM »
If you are looking for "Niedrige Solar Radiation" then it's also in lang_de.txt.
I don't understand why you aren't seeing these translations in your file  :?
Offline zitterbacke
  • Win NT 10.0
  • Firefox 65.0
« Reply #329 on: February 10, 2019, 10:19:40 PM »
Yes, now I found it. Thanks for the hint. Obviously I didn't read the lang_de.txt file carefully enough before. 8O
