Don't translate ajaxWDwx.js
I have a translation into Serbian. And everything works except translationfor ajaxWDwx.js. I have made a translation into language-sr. js but does not update the translation page.
http://vreme.in.rs/knjazevac/index.php
I noticed that updating the current conditions is not working at all. It is possible that this is the problem.
You don’t seem to have the check-fetch-times.php utility installed on your site – without that, I really can’t help diagnose the issue.
Please install the utility from here and reply when it is available on your site.
Thanks… Ken
I install the utility. Now is available on my site.
Thanks … Boce
Hi, and thanks for doing that. Using check-fetch-times.php?show=versions indicates you have a lot of script updates to do … (from 16-Feb-2013 for Base-World, WD-plugin).
You seem to have heavily modified top.php and have removed the parts that load/handle the language-sr.js language translation, so that is why it is being ignored (it’s never loaded by the page).
I upload new top.php from Base-World and nothing happened. Do I need to edit script top. php to load language-sr.js?
I also noticed that the current conditions is being updated from testtags.php and not from clientraw.txt!?
One more question. How to add daily values ​​for UV, Solar kWH, ET on the report pages wxuvdetail. php, wxsolardetail. php. . . ?
Looking at your site with check-fetch-times.php?show=structurer shows the old top.php is still there (and still missing the features to load the language translation .js script). Feel free to use this as your top.php
<?php
# A Project of TNET Services, Inc. and Saratoga-Weather.org (Base-* template sets)
#	Project:	Sample Included Website Design
#	Module:		top.php
#	Purpose:	Provides the initial top section of the website
# 	Authors:	Kevin W. Reed <[email protected]>
#				TNET Services, Inc.
#               Ken True <[email protected]>
#               Saratoga-Weather.org
# 	Copyright:	(c) 1992-2007 Copyright TNET Services, Inc.
# This program is free software; you can redistribute it and/or
# modify it under the terms of the GNU General Public License
# as published by the Free Software Foundation; either version 2
# of the License, or (at your option) any later version.
# This program is distributed in the hope that it will be useful,
# but WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
# GNU General Public License for more details.
# You should have received a copy of the GNU General Public License
# along with this program; if not, write to the Free Software
# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA  02111-1307, USA
#	This document uses Tab 4 Settings
require_once("Settings.php");
require_once("common.php");
global	$TITLE;
//Version  V3.01 - 03-Mar-2011 - added Content-Type header for charset switching
//Version  V3.02 - 23-Jul-2011 - added WXtags upload copy capability
//Version  V3.03 - 17-Nov-2011 - added support for right-to-left presentation format
//Version  V3.04 - 05-Feb-2013 - added support for HTML5+UTF8
if(isset($useUTF8) and function_exists('set_langtrans_UTF8') ) {
	set_langtrans_UTF8(); // convert langrans items to UTF-8
header("Content-Type: text/html; charset=".strtoupper($SITE['charset']));
if(isset($useHTML5) and $useHTML5) {
  print "<!DOCTYPE html>\n";
  print "<html";
  if (isset($SITE['ISOLang'][$SITE['lang']])) { //
	$olang = $SITE['ISOLang'][$SITE['lang']];
	echo " lang=\"$olang\"";
  print ">\n";
} else {
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN"
   "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<?php
} // end HTML5 v.s. XHTML 1.0 Transitional header
<?php
 if(isset($SITE['WXtags']) and $SITE['WXtags'] <> '') {
	// see if upload copy should be done
	$siteUploadFile = preg_replace('|\.php$|','-new.php',$SITE['WXtags']);
	if(file_exists($siteUploadFile) and
	   is_writable($SITE['WXtags']) and
	   filesize($siteUploadFile) > filesize($SITE['WXtags']) - 1023 and
	   filemtime($siteUploadFile) > filemtime($SITE['WXtags']) ) {
		 $didCopy = copy($siteUploadFile,$SITE['WXtags']);
		 if($didCopy) {
			 print "<!-- WXtags file updated successfully from $siteUploadFile -->\n";
		 } else {
			 print "<!-- WXtags file update failed from $siteUploadFile -->\n";
	if (isset($_REQUEST['debug']) and strtolower($_REQUEST['debug']) == 'y') {
	  $canWriteTags = is_writable($SITE['WXtags'])?"is":"IS NOT";
	  print "<!-- WXtags '".$SITE['WXtags']. "' $canWriteTags writeable. -->";
	include_once($SITE['WXtags']);
 $doIconvUTF8 = ($SITE['charset'] == 'UTF-8' and $SITE['origCharset'] <> 'UTF-8')?true:false;
  <head>
<?php if(isset($SITE['ajaxScript'])) { ?>
    <!-- ##### start AJAX mods ##### -->
    <script type="text/javascript" src="<?php echo $SITE['ajaxScript']; ?>"></script>
    <!-- AJAX updates by Ken True - http://saratoga-weather.org/wxtemplates/ -->
<?php } // end if ajaxScript ?>
<?php if (isset($showGizmo) and $showGizmo) { ?>
    <script type="text/javascript" src="ajaxgizmo.js"></script>
<?php if (isset($SITE['UV']) and !$SITE['UV']) {  // turn gizmo uv display off ?>
    <script type="text/javascript"> showUV = false; </script>
<?php   }  // end of turn gizmo uv display off ?>
<?php } // end of showGizmo ?>
<?php if (file_exists("language-". $SITE['lang'] . ".js") and (!$doIconvUTF8) ) { ?>
    <script type="text/javascript" src="language-<?php echo $SITE['lang']; ?>.js"></script>
	<!-- language for AJAX script included -->
<?php }
  if(isset($useUTF8) and $useUTF8 and file_exists("language-". $SITE['lang'] . ".js") and $doIconvUTF8) {
	$tjsfile = file("language-". $SITE['lang'] . ".js");
	$sceCharset = $SITE['origCharset']; // set in common.php when useUTF8 invoked
	print "    <script type=\"text/javascript\">\n// <![CDATA[ /* converted to UTF-8 from $sceCharset */\n";
	foreach ($tjsfile as $n => $line) {
		print iconv($sceCharset,'UTF-8//TRANSLIT',$line);
	print "// converted ".count($tjsfile)." lines of language-".$SITE['lang'].".js from $sceCharset to UTF-8 inline -->\n// ]]\n    </script>\n";
    <meta name="description" content="Personal weather station." />
    <meta http-equiv="Content-Type" content="text/html; charset=<?php echo strtoupper($SITE['charset']); ?>" />
    <link rel="stylesheet" type="text/css" href="<?php echo $SITE['CSSscreen']; ?>" media="screen" title="screen" />
    <link rel="stylesheet" type="text/css" href="<?php echo $SITE['CSSprint']; ?>" media="print" />
	<link rel="shortcut icon" href="/favicon.ico" type="image/x-icon" />
<?php
if(isset($useHTML5) and $useHTML5) { // no pragma/cache-control for us
} else { ?>
	<meta http-equiv="Pragma" content="no-cache" />
    <meta http-equiv="Cache-Control" content="no-cache" />
<?php } // end HTML5 check
if(isset($SITE['showTitleTemp']) and $SITE['showTitleTemp'] and isset($temperature)) {
  $dispTUOM = $temperature . '&deg;'.strtoupper(preg_replace('|[^CF]+|i','',$uomtemp)). ' - ';
} else {
  $dispTUOM = '';
if( isset ($TITLE) ) {
	echo "    <title>$dispTUOM" . $TITLE . "</title>\n";
} else {
	echo "    <title>$dispTUOM" . langtransstr($SITE['organ']) . "</title>\n";
if (isset($SITE['flyoutmenu']) and $SITE['flyoutmenu'] or
	isset($_REQUEST['menu']) and strtolower($_REQUEST['menu']) == 'test' ) {
  $SITE['flyoutmenu'] = true;
  $PrintFlyoutMenu = false;
  $genDiv =false;
  global $FlyoutCSS, $FlyoutMenuText;
  include_once('flyout-menu.php');
  print $FlyoutCSS;
// Right-to-left language CSS mod
if(isset($SITE['CSS-RTL']) and file_exists($SITE['CSS-RTL']) and isset($SITE['RTL-LANG']) and
   (strpos($SITE['RTL-LANG'],$SITE['lang']) !== false) ) { // use the override CSS
   print "<!-- lang='".$SITE['lang']."' using RTL CSS Override -->\n";
  // print "<style type=\"text/css\">\n";
  // readfile($SITE['CSS-RTL']);
  // print "</style>\n";
  print "<link rel=\"stylesheet\" type=\"text/css\" href=\"".$SITE['CSS-RTL']."\"/>\n";
} // end Right-to-left CSS override
<!-- World-ML template from http://saratoga-weather.org/wxtemplates/ -->
<!-- end of top -->
The ajaxWDwx.js will load the current conditions from clientraw.txt to update SOME of the values. The remaining values are provided by testtags.php for the site.
Adding daily values to wxuvdetail.php, wxsolardetail.php will be left to you… those are not my pages, but likely from Murray’s add-on pages. Sorry.
Thank you Ken! Happy Christmas! :slight_smile:
On my homepage http://vreme.in.rs/knjazevac/index.php current conditions don’t update from clientraw but on http://vreme.in.rs/knjazevac/ajax-dashboard-testpage.php?show=ajax they do.
I don’t know why?
Your main site is still not using the top.php that I posted above. That is why it is not working.
