Author Topic: Which version of WD for Raspberry Pi 3 Model B+ (Plus)  (Read 893 times)
Offline CurtisZM
  • Zumbrota, MN
  • Win NT 10.0
  • Chrome 70.0.3538.110
    • CurtisZMWeather
« on: December 17, 2018, 03:25:27 AM »
Brian,
 Which WD Linux version should I download for my Raspberry Pi 3 Model B+ (Plus)? I just purchased it and downloaded the latest OS (Raspbian).
 1.4GHz 64-bit quad-core processor, dual-band wireless LAN, Bluetooth 4.2/BLE, faster Ethernet, and Power-over-Ethernet support (with separate PoE HAT)
 I tried Weather Display for Linux console 64 bit Raspberry pi3 Version on 5 July 2018 - 01:45:27 and ./GoWdconsole.sh doesn't work.
 Thank you.
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
Re: Which version of WD for Raspberry Pi 3 Model B+ (Plus)
« Reply #1 on: December 17, 2018, 06:36:50 PM »
do not use the .sh
instead run more direct
as per the readme
i.e copy the files in the deploy folder to /usr/local/lib/ and /usr/lib/
and then run like
sudo ./consolewd
Offline CurtisZM
  • Zumbrota, MN
  • Win NT 10.0
  • Chrome 71.0.3578.98
    • CurtisZMWeather
« Reply #2 on: December 18, 2018, 02:43:41 AM »
Here is what I'm getting when executing the command:
[email protected]:~/Desktop/consolewdfiles $ sudo ./consolewd
sudo: ./consolewd: command not found
Here is what is in the directory:
[email protected]:~/Desktop/consolewdfiles $ dir
config.txt      cronmysql           datafiles        tagslist.txt
consolewd      cronmysql2           deploy        wdconsole.ini
croncwop      cronwindfinder        GoWdconsole.sh  wxlocal.html
cronftp         cronwow           libhid.so.0
cronftpnoaareport  cronwu           logfiles
cronftpreal      customclientrawlocal.txt  readme.txt
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #3 on: December 18, 2018, 04:08:23 AM »
that error usually means its the wrong cpu type (architecture)
Offline CurtisZM
  • Zumbrota, MN
  • Win NT 10.0
    • CurtisZMWeather
« Reply #4 on: December 18, 2018, 11:38:26 AM »
 More than likely your apps might not work with the newer model Raspberry pi?
  Thank you for your assistance..
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #5 on: December 18, 2018, 05:57:28 PM »
i would need to have one here and compile on that
Offline CurtisZM
  • Zumbrota, MN
  • Win NT 10.0
    • CurtisZMWeather
« Reply #6 on: December 18, 2018, 08:11:24 PM »
What is the latest supported model? Thanks so much for your assistance.
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #7 on: December 19, 2018, 12:17:17 AM »
Pi3 Revb  vers 1.2
using
cat /sys/firmware/devicetree/base/model
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #8 on: December 29, 2018, 12:11:58 AM »
in case I had the wrong version uploaded, I have re uploaded it
