WeatherDisplay seen as Ransomeware by Malwarebytes
I just updated from 10.37S build 82 to build 85. Malwarebytes immediately killed and quarantined it. I restored it, and within a minute or two it was stopped and quarantined again. After one more repeat, Weatherdisplay is gone and no longer shows up in the Malwarebytes quarantine either.
its a false positive
I thought that was the case, but I thought you might like to know, in case others might have the same problem. Something in build 85 is triggering this MalwareBytes response, and the result is nasty - the weatherdisplay.exe file is now locked so I can’t access it. I can’t delete it, rename it, execute it - nothing works. So I can’t install build 82, or even erase everything and start over.
I’m working with Malwarebytes to resolve this, but if it can be prevented it would be better.
