I have searched and more then likely searched wrong.
I received my new WF and have it working in WD, Can not find how to get the lightening working.
WDL does not have this option to display the values which is not a problem, Not sure if carterlake template does I need to check on this.
Is there something I need to configure in WD for it to use the lightening data from WF?
Is there something I have to enable to tell WD to use the data for lightning from WF?
So far everything else appears to work.
I do see the windrun is off compared to my VP2 results
I get WF with less windrun but higher gust and higher average windspeeds.
I see a few options, I tried the graph option for now and to upload it to my webpage.
Being winter we do not get much lightning.
Is there a way to use this graph in WDL?
I am not sure I trust the readings yet for WF. Only time will tell.
Is there a reason why the windrun is off, I see WF has winds all day that are higher then my Davis, Yet the davis side seems to have a higher windrun.
I assume it is, I am not sure how to get it to graph or try and use it has an extra sensor to display in carter lake. I checked the make graph but have not found it yet. Looking in WD folder for it.
Checked save as webfile looking for that file also.
Not sure if there is an even a way to get the info in WD.
System is still new, and we are lucky WD supports it.
WD supports just about everything out there.
