Need help with width of main screen / Resolved
I’ve made no changes to my settings recently, however this morning the main forecast and temp area of my site is narrow, with the menu off to the far left, as can be witnessed here: www.MohawkValleyWeather.com
How do I go about widening that area?
Rick
It’s not clear what area you want to be wider, or, what changed on your display from before…
The part that got wider is the center section on my home page.
It’s contains the temp, BP, wind, forecast, etc…
Rick
For some reason your page is not showing the “style options” (see attachment). When I set my homepage to wide mode it looks like your page. Perhaps this option has been disabled in your settings?
I uploaded my ajax-dashboard from a saved file, and the issue was resolved.
Rick
Glad you found a fix…it’s clear to me now that what I thought you were trying to do was way off base… :?
Evidently the new Ajax-Dashboard file from Saratoga was the culprit.
My bad cause I didn’t adjust it prior to uploading.
Rick
