Thanks Brian
The only files I see in wdisplay are airqualityaqi.inf and airquality2.txt
Alan
you would need to be using the latest
cronairquality.exe version
1.5
modified create/time on that file should be 26 Nov
yes?
Thanks Brian - The cronairquality.exe is dated 26/11/2018 but the version says 1.0.0.0
It was in weatherdisplaytest.zip which I didn’t download until 19/12/2018 I’ll check if there is a later one.
Alan
Hi Brian I downloaded the zip file in Suggestions (26/11/2018) again and still get just airquality2.txt and the cronairquality.exe is also 1.0.0.0
Alan
the version number is shown when you actually open the program (i.e make it visible from the icon from the system tray) but you would need to be fast
anyway, use this test version
backup your current version
and see if it shows a message when its run
http://www.weather-display.com/downloadfiles/cronairquality.zip
is that the correct IP address to get the indoor data?
Hi Brian
Hope the flu is better - all the best for 2019
That IP is the luftdaten sensor for PM / temp / humid and it is the temp & hum which I would like to see instead of the indoors
All data arrives from 192.168.0.161/data.json (the address I have set in purple air set up). I managed to get round the router changing the ip but the selectable ip is handy as my fix doesn’t guarantee a static ip.
Regards
Alan
what should the url be
I don’t quite understand - the temp and hum data is already imported via the purple air luftdaten option which is filed as airquality2.txt. I’ll attach it again. Presumably you get the PM figures from there as well. Sorry if I’m missing something here !!
Alan
airquality2.txt (468 Bytes)
ah
there is option to have another sensor…and so with a different ID number…to use that as the temp/hum sensor
but you want just your main (and only) sensor to be used, yes?
I will need to add that option
for simplicity
if you set the id to use use for temp/hum as your current sensor
then it will just use that
try this update
and see if that procuces the airquality3.txt file
That produces the airquality3.txt but opening it with notepad only gives a symbol - no text.
Just to clarify - I don’t need indoor temp and humidity and would use the space on the main screen for the (more accurate than wmr300) temp and humidity produced by the luftdaten sensors. The data already seems to be available in the airqual txt files.
Alan
what I will do is to add option to use the temp/hum from the main sensor as normal outdoor temp/hum , yes?
When you say main sensor - that is disregard what comes from the weather station as indoor t/h and use the luftdaten temp/hum. If so that’s fine.
There is an option to re- label the indoor t/h I think
Sorry if this has become more complicated than it first looked.
Late now here so replies - if needed - tomorrow. Thanks
Alan
its not very clear
one minute you talk about indoor temp/hum
then you don’t
please explain more clearly exactly what you are needing
Sorry - The wmr300 produces t/h values for indoors as shown on the main screen. I don’t need those and would rather use the space on the screen for the values from the luftdaten sensors. Under the purple air set up it looks as though there is an option to do that but it does not work for the wmr300. You mentioned earlier an override could be put in so the wmr values are ignored. The values I would like shown instead are already imported as a data.json file (airquality2.txt) from the luft sensors . It looks as though the indoor t/h labels can be changed in the advanced/misc set up.
I hope that makes it clear and I really appreciate your time spent for a one off request.
Alan
OK
so you need the normal main luftdaten sensor temp/hum to be basicly extra temp/hum data that you can then do what you like with in WD (i.e show on main screen etc)
have added that option now to this udpate
