I had a problem with my rain gauge yesterday where, for some reason, it showed a completely spurious reading where 7.9mm became 17.9mm.
To fix this (successfully) I
Corrected the value in View Modify Log Files/Rain Totals and clicked on Use the correct amount.
Then in Average/Extreme NOAA Style Reports clicked on Update whole month now.
Then in Recreate the Web Av/Ext clicked on Reset the webpage/extreme.
Then uploaded the new November2018.htm file and all is correct.
However the raindetail.gif graph is still showing the incorrect measurement. To try and sort this I used,
Control panel, Graph setup, Graph Interval/Clear/Correct Graph, Graph Correct, entered Start and End days, ticked Daily Rain Correction, clicked Correct and Save, but this does not alter the reading in either raindetail.gig or windtempraintrend11.gif
Is there a way to correct these graphs?
Any help would be very much appreciated.
Thanks garyghj
