Author Topic: Multiple Gauges from different stations on the same page?  (Read 578 times)
Offline JohnZ
  • Greece, Kavala
  • Win NT 10.0
  • Firefox 63.0
    • Kavala's Weather Page
« on: November 27, 2018, 01:25:25 PM »
As the title say, is that possible in some way?
I have tried different things on the code, but can't seem to find a way to call for example 2 different Temp gauges and get different data for each one.
Situation is like this:
I have 2 stations with WD/Customclientraw in those paths
meteokav.gr/weather/ssg/  Station 1
meteokav.gr/vounochori/ssg/  Station 2
And I want to display 2 temp gauges on my homepage https://www.meteokav.gr/index2.php  (index2 is just a test index until I find a solution)
On index2.php I have
Code: [Select]
<!-- SSG Tools/API -->
<script src="https://code.jquery.com/jquery-1.11.1.min.js"></script>
<script src="weather/ssg/scripts/steelseries_tween.min.js"></script>
<script src="weather/ssg/scripts/language.min.js"></script>
<script src="weather/ssg/scripts/gauges-main-el.js"></script>   <-- Station 1
<script src="vounochori/ssg/scripts/gauges-main-el.js"></script> <--- Station 2
<script src="weather/ssg/scripts/RGraph.common.core.min.js"></script>
<script src="weather/ssg/scripts/RGraph.rose.min.js"></script>
And in order to call the 2 different gauges for station 1:
Code: [Select]
    <div class="row">
                      <div id="tip_0" class="gauge">
                         <canvas id="canvas_temp" class="gaugeSizexSml" width="150" height="150"></canvas>
                </div>
Which is working fine, its basically the 1st station in /weather/
However the station in /vounochori/ doesnt seem to get data, the gauge graphic loads fine though.
Code: [Select]
<div class="row">
                         <canvas id="canvas_temp2" class="gaugeSizexSml" width="150" height="150"></canvas>
         </div>
As you can see in the 2nd station I tried to change the id into "canvas_temp2" and at the same time I changed all the "canvas_temp" in the  vounochori/ssg/scripts/gauges-main-el.js  into -> canvas_temp2.
I also have tried to include the different ssg setups via <iframe> and <?php include> tags but still the result was the same, only the 1st gauge was working.
Any ideas around this situation? Not sure if this is possible at all in a simple way but yeah, any help would be really appreciated :)
Offline mcrossley
  • Wilmslow, Cheshire, UK
    • none
  • Win NT 10.0
  • Chrome 70.0.3538.110
    • WilmslowAstro Weather
Re: Multiple Gauges from different stations on the same page?
« Reply #1 on: November 27, 2018, 06:25:24 PM »
You could be in for a bit of digging here!
First thing I would say is that the two scripts have a name clash. The scripts try to keep all their variables private by encapsulating the code within an immediate function.
So, at the top of teh script you have...
Code: [Select]
var gauges = (function () {
In you second script change that to...
Code: [Select]
var gauges2 = (function () {
Another problem, the script uses jQuery to perform the AJAX queries. It assumes it has sole access, so the two scripts will interfere with each other - e.g. line 2616...
Code: [Select]
if ($.active > 0)$.active will be greater than zero if the "other" script is currently running a query. :(
Horrible hack - just comment out the following _jqXHR.abort(); command!
With those two changes the gauges function - how reliably though....
« Last Edit: November 27, 2018, 06:28:07 PM by mcrossley »
Mark
Offline JohnZ
  • Greece, Kavala
  • Win NT 10.0
  • Firefox 63.0
« Reply #2 on: November 27, 2018, 08:05:48 PM »
Mark! It's magic!  :o
Thank you very much, seems like everything working :) If I see anything weird I will report back. Actually is there something that might break after a while?
Best regards! :)
Offline JohnZ
  • Greece, Kavala
  • Win NT 10.0
  • Firefox 63.0
« Reply #3 on: November 27, 2018, 09:55:25 PM »
Up and running, not 2 but 4 stations! :lol: Let's see how this will turn around :)
Again, many thanks Mark!
« Last Edit: November 27, 2018, 09:57:48 PM by JohnZ »
