Author Topic: Modified rain gauge collection  (Read 609 times)
Offline Ian Sharpe
  • near Braidwood, NSW, Aus
  • Win 7/Srvr 2008R2
  • Firefox 63.0
« on: November 19, 2018, 06:48:10 AM »
Hi Brian,  I have added a funnell collector to my rain gauge theerfore increasing the collection area.
The figure I need to put into WD is .309 however in the rain offset  area there is only a % increase & the new gauge tip is set to 1 & cant be changed, is that normal now? Using OS WMR89 if thats any help.
« Last Edit: November 19, 2018, 06:55:09 AM by Ian Sharpe »
Offline bitsostring
  • Oregon Scientific WMR200
  • Edinburgh, UK
  • Chrome 64.0.3282.140
    • Home Weather Station
Re: Modified rain gauge collection
« Reply #1 on: November 19, 2018, 04:50:48 PM »
Look in Control Panel/Units & Other Settings/Rainfall Setup, where you should be able to enter the new tip.
It's meant to be fun. . .
Offline Ian Sharpe
  • Win 7/Srvr 2008R2
  • Firefox 63.0
« Reply #2 on: November 19, 2018, 05:49:16 PM »
great thanks, I see it now, just for info what is the other one for, the one in the offsets option?
Offline bitsostring
  • Edinburgh, UK
« Reply #3 on: November 19, 2018, 06:00:13 PM »
Does that not change too, when you put the new tip into Rainfall Setup?
Offline Ian Sharpe
  • Win 7/Srvr 2008R2
  • Firefox 63.0
« Reply #4 on: November 19, 2018, 07:33:34 PM »
Only seem to be able change the % in this option , the other value defaults to the value in the rainfall setup option.
« Last Edit: November 19, 2018, 07:37:22 PM by Ian Sharpe »
Offline bitsostring
  • Edinburgh, UK
« Reply #5 on: November 19, 2018, 07:36:59 PM »
In answer to your original question that you've edited out (what's the second occurrence of tip setting for?), I don't know! It's probably a legacy thing. . . :wink:
« Last Edit: November 19, 2018, 07:46:22 PM by bitsostring »
Offline niko
  • syzygy
  • Northern California, U.S.A.
  • Win 7/Srvr 2008R2
  • Chrome 70.0.3538.102
« Reply #6 on: November 19, 2018, 07:39:05 PM »
The offset came first and is intended to make small changes to correct perceived inaccuracy of the tip size of a factory gauge (which originates from the station type set up). The other setting is to accommodate a wide range of tip size of a non standard, modified gauge.
Offline Ian Sharpe
  • Win 7/Srvr 2008R2
  • Firefox 63.0
« Reply #7 on: November 20, 2018, 07:02:51 PM »
ok thanks guys
Offline Ian Sharpe
  • Win 7/Srvr 2008R2
  • Firefox 63.0
« Reply #8 on: November 21, 2018, 01:01:05 AM »
ok, so i changed my rain offset to .309 however its not reducing the rainfall by that amt. We just had a little over 1mm rain (as verified by my plastic rainguage) but WD registered it as 4.1mm. I also just did a practice tip of the OS guage & it registered as 1mm on WD.
ANy ideas?
cheers
Offline bitsostring
  • Edinburgh, UK
« Reply #9 on: November 21, 2018, 02:39:57 PM »
I presume you set "Modified rain gauge new tip (mm)" to 0.309, not the "Rainfall offset (% increase)"?
If so, I don't know what is wrong. Mine works fine with a 200 mm funnel giving a new tip of 0.25 mm: WD shows 1 mm for every 4 mm shown on the console - with a few rounding problems because rain is shown to 1 d.p.
« Last Edit: November 21, 2018, 03:10:39 PM by bitsostring »
Offline niko
  • syzygy
  • Win 7/Srvr 2008R2
« Reply #10 on: November 21, 2018, 03:31:10 PM »
Did you restart WD after making the change?
Offline Ian Sharpe
  • Win 7/Srvr 2008R2
  • Firefox 63.0
« Reply #11 on: November 21, 2018, 05:46:55 PM »
yes i did, but still no go.
  • Davis VP2
    • Weather Display
« Reply #12 on: November 21, 2018, 07:25:32 PM »
I did not have the code in place for the WMR89 station
use this version
Offline Ian Sharpe
  • iOS 11.2.6
  • Safari 11.0
« Reply #13 on: November 21, 2018, 08:59:03 PM »
Great thanks Brian , Iíll give it a go when I get home , cheers
Offline Ian Sharpe
  • Win 7/Srvr 2008R2
  • Firefox 63.0
« Reply #14 on: November 22, 2018, 07:15:57 AM »
Hi Brian , thanks for the file, unfortunately i cant install it, i get this message  PAKBUSDLL.DLL was not found, i found a post about it earlier but still cant install the new version, any ideas, sorry. BTW the previous version still works, odd
« Last Edit: November 22, 2018, 07:19:59 AM by Ian Sharpe »
