Author Topic: cronlazersnow.exe won't run  (Read 1443 times)
Offline Dennis48755
  • Sand Point, Michigan
  • Win NT 10.0
  • Firefox 63.0
    • Sand Point Michigan Weather
« on: November 09, 2018, 03:49:27 AM »
Hello,
It's that time of the year, here in Michigan, to get the Porcupine modified Fluke laser measuring tool setup for the winter.
I set it up and had it running great with WD just as the snow ended last winter.
When I enable (check box) the two options for "USB Laser Snow Sensor" & "Use cronlazersnow.exe" and restart WD, I don't find cronlazersnow running as I did last winter.
When I attempt to start cronlazersnow manually by double clicking on the file in the wdisplay folder, I see a momentary outline of a window opening but it quickly disappears.
Both of the Porcupine utilities, LrDemo.exe and LRTimeLog.exe run and read the laser sensor measurement properly.
I do understand and am careful while testing, that only one program that accesses the USB port can be running at any one time.
Thanks in advance for any help and/or suggestions.
Dennis
Online Weather Display
  • Davis VP2
  • New Zealand
  • Win NT 10.0
  • Chrome 70.0.3538.77
    • Weather Display
Re: cronlazersnow.exe won't run
« Reply #1 on: November 09, 2018, 06:57:20 AM »
try starting it again
Offline Dennis48755
  • Win NT 10.0
  • Firefox 63.0
« Reply #2 on: November 09, 2018, 04:12:41 PM »
Brian,
I'm not sure I understand, are you being sarcastic?
I've tried starting cronlazersnow dozens of times with the above results.
I wouldn't come here asking for help with the single occurrence of a problem.
Dennis
Update: In an attempt to do further troubleshooting, I have disabled my antivirus & firewall software. I also restarted the computer without any additional (my normal startups) software and tried manually starting cronlazersnow.exe both the current version and a copy of 2.7. Same results, very quick flash of what looks like it could be a window trying to open, but it disappears.
« Last Edit: November 09, 2018, 04:59:01 PM by Dennis48755 »
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #3 on: November 09, 2018, 06:50:11 PM »
I wasn't
as the first time it ran it might have had the message from WD to close (which then will get reset (should do) for the next time you run it
maybe its still running in the windows system tray
Offline Dennis48755
  • Win NT 10.0
  • Firefox 63.0
« Reply #4 on: November 09, 2018, 08:09:09 PM »
I do not find any instance of it running, looking at/in the taskbar, system tray and task manager.
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #5 on: November 09, 2018, 08:37:30 PM »
try this update
http://www.weather-display.com/downloadfiles/cronlazersnow.zip
it was closing before if there was any error
Offline Dennis48755
  • Win NT 10.0
  • Firefox 63.0
« Reply #6 on: November 09, 2018, 09:22:27 PM »
Brian,
YES, that version works, BUT is posting an error; Device cannot be opened at time/date...
Even with the error message, if I click "Take Reading Now", LRTimeLog.exe opens/runs and takes measurements.
No additional messages are posted in cronlazersnow.
See attachment.
Dennis
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #7 on: November 09, 2018, 09:49:05 PM »
try another update, same url
Offline Dennis48755
  • Win NT 10.0
  • Firefox 63.0
« Reply #8 on: November 09, 2018, 10:43:55 PM »
That gives the same symptoms as the previous version.
Opens with error, LRTimeLog.exe reads sensor, dosen't post messages to cronlazersnow
Dennis
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #9 on: November 09, 2018, 10:55:21 PM »
what is the error this time?
Offline Dennis48755
  • Win NT 10.0
  • Firefox 63.0
« Reply #10 on: November 09, 2018, 11:13:57 PM »
Device cannot be opened.
Dennis
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #11 on: November 10, 2018, 12:00:26 AM »
are you sure you are using that latest update
what is the modified date/time on the .exe file
Offline Dennis48755
  • Win NT 10.0
  • Firefox 63.0
« Reply #12 on: November 10, 2018, 12:58:19 AM »
I've been trying to be careful.
cronlazersnow.exe   13,289,088   11/09/2018 16:47
Dennis
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #13 on: November 10, 2018, 01:02:51 AM »
that has the wrong time stamp
try downloading again?
Offline Dennis48755
  • Win NT 10.0
  • Firefox 63.0
« Reply #14 on: November 10, 2018, 01:12:28 AM »
Zip contains the same file, with date time that I just sent you.
