Author Topic: Dashes for yesterday's Max and min Temperature values. (Resolved)  (Read 529 times)
Offline atsio
  • Weather at Thessaloniki - Northern Greece.
  • Macedonia is GREECE! Study history!
  • Thessaloniki - Greece
  • Win NT 10.0
  • Chrome 70.0.3538.77
    • Weather conditions at Thessaloniki Historical Center-Central Macedonia-Greece
Brian, after upgrading to the last two WD builds (82 released at 01/04/2018 and the latest 83 at 04/11/2018), the yesterday's temperature tags are replaced with dashes.
I rolled back to build 82 (released at 17/10/1918) and the problem is resolved!
Have a look at the attached image.
Thanos
http://www.meteothes.gr
« Last Edit: November 06, 2018, 04:41:15 AM by atsio »
  • Davis VP2
  • New Zealand
  • Win NT 10.0
  • Chrome 69.0.3497.100
    • Weather Display
Re: Dashes for yesterday's Max and min Temperature values.
« Reply #1 on: November 05, 2018, 02:31:31 AM »
that was a bug I introduced, which I have fixed in build 83
(for the next daily reset it will fix it)
sorry about that
Offline atsio
  • Win NT 10.0
« Reply #2 on: November 05, 2018, 05:16:04 AM »
Thanks Brian, I'll check it tonight!  :)
Thanos
Offline atsio
  • Win NT 10.0
Re: Dashes for yesterday's Max and min Temperature values. (Resolved)
« Reply #3 on: November 06, 2018, 04:40:34 AM »
Ok Brian, it has been fixed in latest build 83!
After the midnight reset, the yesterday's temp values came back to mormal. :)
Thanos
Offline Joseph Weather
  • Joseph Oregon USA
  • Win NT 10.0
  • Firefox 63.0
    • Joseph Oregon Weather
« Reply #4 on: November 07, 2018, 02:15:57 PM »
For my setup the yesterdays high humidity and low barometer are still blank with the newest version after the midnight roll over.
Scott
http://www.josephoregonweather.com
Home hive of the world famous WeatherBee
Davis WM II, Heated rain collector
Windows 10 64-bit
Offline gwwilk
  • Lincoln, NE
  • Win NT 10.0
    • Southeast Lincoln Weather
« Reply #5 on: November 07, 2018, 02:26:08 PM »
I'm back to 'NaN' for yesterday's high and low, along with 'NaN' for Dewpoint High and Yesterday's Wind Chill. :(
(Removed 'Resolved' from the title of my post!)
I will restore a b82 known fully functional version of WD until these errors get sorted out..,
« Last Edit: November 07, 2018, 02:30:21 PM by gwwilk »
Regards, Jerry Wilkins
gwwilk@inebraska.com
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #6 on: November 08, 2018, 12:19:08 AM »
I am not seeing a problem myself here with build 83
maybe try downloading it again?
Offline dan43
  • Oregon Scientific WMR300
  • Port Coquitlam, British Columbia, Canada
  • Win NT 10.0
    • Port Coquitlam Weather
« Reply #7 on: November 08, 2018, 03:13:35 AM »
I'm using 10.37S B83, and I still have this issue.  How can it be fixed?
« Last Edit: November 08, 2018, 03:18:15 AM by dan43 »
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #8 on: November 08, 2018, 03:21:51 AM »
what do you see when you go to view, daily hi/low data, in WD
(and by doing that, does that fix the issue on the web page)
Offline dan43
  • Win NT 10.0
« Reply #9 on: November 08, 2018, 06:41:40 AM »
I see the "Extra Daily High/Low Weather Parameters" page, and all of the values for Yesterday are filled in.  The values on my main page have been filled in!  Thank you for this!
Point of note, the Daily Low Barometer value and time fields are blank.
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #10 on: November 08, 2018, 06:55:49 AM »
I see what the issue is then
use a new WD update to fix
Offline dan43
  • Win NT 10.0
« Reply #11 on: November 09, 2018, 12:40:38 AM »
Thanks Brian.  Are you releasing B84 to address this issue?  I'm not sure I fully understand your statement above, "use a new WD update to fix".
« Last Edit: November 09, 2018, 12:42:24 AM by dan43 »
Offline gwwilk
  • Lincoln, NE
  • Win NT 10.0
« Reply #12 on: November 09, 2018, 12:59:58 AM »
B83 2018 Nov 8 addresses the issue nicely.
Thanks, Brian! :)
