Wifi Logger Vantage Pro 2 and Weather Display
If I use the Wifi Logger attached to my Davis Vantage Pro 2 console will I still be able to use my Weather Display software?
Can Weather Display get the data from a Wifi Looper which is currently being sold?
Did you see this recent discussion?
do you mean you currently have a usb data logger or a normal ip data logger?
its not very clear
yes WD can work with the wifi data logger (you set up as a ip data logger in WD)
Thank you…did not realize it’s been covered extensively!!!
