is there any pattern?
i.e at a certain time?
or?
Every 5 minutes it will do it…I
Nothing shows in my event log. Every 5 minutes this is what WD does
what do you have set to update every 5 minutes?
see if you can isolate it
I have quite a few things. AWEKAS, WU, Anywheather, meteotemplate, plus file creations under web files #1 and #2, plus a few more.
The interesting thing is not all of my settings restored now that I
if you could email me your settings files I will see if I can duplicate a problem here
it might be a corrupt file or similar
e.g in the datafiles or webfiles folder
(try renaming those folder when WD is not running, then start up WD…as a test)
I will do all of this shortly
I
if you renamed the webfiles folder
and so a new one was created
then that would be empty
i.e it would not have the needed testtags.txt file in it, etc
Makes sense, getting my config file yto you in a few
Where would one get the latest test rags.txt?
you should have the default one where WD is installed to (e.g c:\wdisplay\ )
Got it. Here is my config file. so since WD isn’t crashing now, how do I figure out what the problem was? or how do I get all my previous data back?
you should never post your settings files on a public server
I would delete that
re the next Q
you could add back files from the original webfiles folder until you find the culprit
Thank you
So basically I start adding in the data files for WD to see all previous months and years of data? For some reason WD had my all time records, however my website does not reflect that.
http://rudmanradar.ddns.net:8888/
I get some
its not clear to me what I am supposed to check up on etc on your web page?
do you have the tags into your testtags.php on your server
like this
$maxtemp4today = ‘16.8’; // max from station’s records
$mintemp4today = ‘-0.1’; // min from station’s records
$maxtemp4todayyr = ‘2013’; // max year from station’s records
$mintemp4todayyr = ‘2012’; // min year from station’s records
And into your datafiles on C:wdisplay /datafiles most go back more than 2 years ago
If not that option will not work !!!
I did have the same problem 2 weeks ago
Hope this will help you
[quote author=portsmouthriwx link=topic=67194.msg539800#msg539800 date=1540733430]
I get some
It is updating but Upon converting all my log files to data files, I
