Author Topic: WD Keeps Crashing...  (Read 870 times)
Offline portsmouthriwx
  • Bristol, RI USA
    • The Rudman Radar Live Weather
« on: October 24, 2018, 10:01:23 PM »
Since 10/12/2018, WD keeps crashing. All Windows says it that WD has stopped working and couldnít find a solution and only gives me the option to close the program. I thought it was my computer so I got another one and installed a fresh and latest copy of WD...I restored all data and the same thing is happening. It seems that itís when WD tries to update web files and the internet... any ideas?
Sent from my iPhone using Tapatalk
Davis Vantage Pro 2 Plus, Windows 7 SP1, WD 10.37S36
  • Davis VP2
  • New Zealand
  • Win NT 10.0
  • Chrome 69.0.3497.100
    • Weather Display
Re: WD Keeps Crashing...
« Reply #1 on: October 24, 2018, 10:40:23 PM »
is there any pattern?
i.e at a certain time?
or?
  • Bristol, RI USA
« Reply #2 on: October 24, 2018, 10:42:15 PM »
Every 5 minutes it will do it...Iíve manually tried to update internet and/or web files and it crashes
  • Bristol, RI USA
« Reply #3 on: October 24, 2018, 10:57:13 PM »
Nothing shows in my event log. Every 5 minutes this is what WD does
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #4 on: October 24, 2018, 11:19:26 PM »
what do you have set to update every 5 minutes?
see if you can isolate it
  • Bristol, RI USA
« Reply #5 on: October 24, 2018, 11:32:14 PM »
I have quite a few things. AWEKAS, WU, Anywheather, meteotemplate, plus file creations under web files #1 and #2, plus a few more.
The interesting thing is not all of my settings restored now that Iím looking through settings. Some services arenít even turned on. Iím starting to wonder if something is corrupted.
I have shutoff everything I can think of, no file creations are turned on, main internet switch is off.
Still crashing on the 5ís
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #6 on: October 25, 2018, 12:04:04 AM »
if you could email me your settings files I will see if I can duplicate a problem here
it might be a corrupt file or similar
e.g in the datafiles or webfiles folder
(try renaming those folder when WD is not running, then start up WD...as a test)
  • Bristol, RI USA
« Reply #7 on: October 25, 2018, 12:18:58 AM »
I will do all of this shortly
  • Bristol, RI USA
« Reply #8 on: October 27, 2018, 04:28:11 PM »
Iím sorry I havenít sent you my config file, but just to update, I at least renamed both folders you mentioned and it seems like WD has stabilized. However it seems itís still not FTPíing my files, and real-time updates arenít so real-time. Also it doesnít seem like itís updating any of the services I send data to. All services are on in their own settings and the main internet switch is on. I also seem to be missing the testtags.txt file but WD is set to create them and doesnít seem to be doing so.
« Last Edit: October 27, 2018, 04:31:12 PM by portsmouthriwx »
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #9 on: October 27, 2018, 07:14:56 PM »
if you renamed the webfiles folder
and so a new one was created
then that would be empty
i.e it would not have the needed testtags.txt file in it, etc
  • Bristol, RI USA
« Reply #10 on: October 27, 2018, 07:56:47 PM »
Makes sense, getting my config file yto you in a few
  • Bristol, RI USA
« Reply #11 on: October 27, 2018, 08:22:39 PM »
Where would one get the latest test rags.txt?
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #12 on: October 27, 2018, 08:31:17 PM »
you should have the default one where WD is installed to (e.g c:\wdisplay\ )
  • Bristol, RI USA
  • Mac OS X 10.14
  • Safari 12.0
« Reply #13 on: October 27, 2018, 09:00:08 PM »
Got it. Here is my config file. so since WD isn't crashing now, how do I figure out what the problem was? or how do I get all my previous data back?
« Last Edit: October 27, 2018, 09:54:33 PM by niko »
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #14 on: October 27, 2018, 09:42:29 PM »
you should never post your settings files on a public server
I would delete that
re the next Q
you could add back files from the original webfiles folder until you find the culprit
