I have finally moved from an old PC with Windows XP to a new one with Windows 10. I copied the c:\wdisplay folder and then installed the WD 10.37S82. I’ve managed to adjust most things and resize the main screen so that it’s readable on both PC and web clients, but dailyhighlowbaroetc.gif has me stumped. #-o
Changing height and width only affect how the .gif is displayed. I need the generated .gif to include all the data. On the WD computer clicking on “Extreme Conditions” on the main screen illustrates the problem - the (sub-)window is not resizable
Brian, that fixed the WD screen until the time came for FTP. The height stayed the same but the width reduced to remove the yesterday’s time column. Ross
that is because the web image is expecting a fixed size based on normal windows resolution
what I can do is make it so that WD does not do that if you have changed the size from default
Brian, formatting is good, but a few blanks in “yesterday’s” figures. Will see what it looks like when the day kicks over at 9am and report back. Thanks, Ross
I just installed the S82 version in the main download installation.
But there is no problem that you have here.
However, as you can see in the picture, the color change does not work in two boxes.
