If you don’t always leave the program running overnight, when you start in the morning and read in the data it:
uses a different spacing for time on the graphs, i get that there aren’t as many data points; and,
doesn’t do the midnight reset. Seems like as the data comes in it could be asking “did it pass midnight?” and go off to the reset routine for a moment.
perhaps a margin of error could be introduced. I don’t remember now if the timestamps are every 5 or 10 minutes, but it often is outside its existing check and doesn’t do it.
Keep in mind that Ambientweather.net submissions require an API key, and if you didn’t purchase your hardware/software (like Weatherbridge) from Ambientweather.com, you’ll likely have to pay for a key to submit data there. $150 (ouch).
Their authorization is by Device ID (DID) … unauthorized DIDs get a reject message from the API.
Brian: The api key has been emailed to info@ email address. Tanks. Ken: Gotcha. I have an api key and am using it well, except as noted regarding WD doing a midnight reset after WD has not been running over night. The Ambient uploads its data independent of the WD.
Daily rain has been ok, because it takes it from Ambient on a per data read basis, but daily highs, lows, wind, humidity, etc continue to read yesterdays highs and lows about half the time. Its inconsistent whether it resets or not. I’ll shut down tonight and if it fails in the a.m. I will screen cap the daily high/low screen.
i had not set to use rain total from station in this test
you had not said or made it clear that sometimes the reset works but other times it does not
when it does not, check the logfile (e.g 10208lg.txt) to see if any missing minute data points around the midnight reset time
Will do. This morning it failed to get data at all the first time i ran the program at startup, i restarted it and failed again. I reset the date/time in the logger and 3d time was a charm, it read in fine and did the midnight reset. I will continue to watch and play and look at that file looking for more/better information i can supply. I don’t always shut it down at night, but realize that intermittent problems are the worst to find.
Its been fine for several days, then today it failed to read the data the first time, closed the program, reopened, it read data, did the midnight reset OK, but has no data for yesterday, see screenshot. Notice the solar maximum, it seems to have a decimal point problem. But, only in that window, the actual data and max/min records are not affected.
if it fails, it might because of the server returning about too many connections/requests
i.e check in the ambientdatahistory.txt and ambientdata.txt files at that time
I had not tested/checked on the daily hi lo yesterday data problem when I last did a test
That’s correct. ambientdata.txt had {“error”:“above-app-rate-limit”} in it, the data was actually fine in ambientdatahistory.txt and it actually read in fine.
The yesterday/today screen did it again. That’s a new phenomena, didn’t used to do that prior to the current build.
i have fixed the issue with the yesterday hi/lo problems I introduced in the latest version
at least
build 83 .zip is ready to download now, to fix that
