Raintoday.gif is not being created. The last update was in early Sept. Where do I turn on the option to update and upload the raintodate.gif file? I must have inadvertently turned it off.
Tom
Tom
make sure you have WD set to update the individual dial images
Thanks Brian. I checked the produce and upload individual dial images but the images are not being created.
Tom
if you are using the customise internet and file creation setup
then make sure you have set to create and upload those there
is there any error under view, program event log?
I am not using the the customise internet and file creation. I did check the log and found numerous instances of
error with file #7 Access violation at address 0080A576 in module ‘WeatherDisplay.exe’. Read of address 0000002C
error with doftpupload Access violation at address 0080A576 in module ‘WeatherDisplay.exe’. Read of address 0000002C
I notices that file 7 is the individual dial images in the customise internet and file creation setup which, as I mentioned, I am not using.
I am using vesion 10.37S Build 81.
Tom
it looks like there is an error occuring with the creation of the individual dial images
for your settings/setup
if you could .zip and email me your settings I can try and duplicate that problem here
Zip file sent.
Thanks Brian.
this has been resolved by a reinstall of WD it seems (via email)
