These tags were posted in the purpleair strangeness thread.
I got the the first 3 working using the luftdaten sensor.
The others do not work.
Are they for the purple air sensor only?
$purpleair2_5 = ‘32.0’; //Value of 2.5 micron particle measure from purple air sensor (see in WD under setup, advanced/misc)
$purpleair10_0 = ‘282.3’; //Value of 10.0 micron particle measure from purple air sensor
$purpleairaqi = ‘94.7’; //AQI (air quality index) value from purple air sensor
$purpleair24hourmean10_0 = ‘282.3’; //Last 24 hours average PM 10.0 value
$purpleair24hourmean2_5 = ‘48.1’; //Last 24 hours average PM 2.5 value
$purpleair24hourmin10_0 = ‘0.0’; //Min value in last 24 hours PM 10.0 value
$purpleair24hourmin2_5 = ‘-1.0’; //Min value in last 24 hours PM 2.5 value
$purpleair24hourmax10_0 = ‘282.3’; //Max value in last 24 hours PM 10.0 value
$purpleair24hourmax2_5 = ‘96.1’; //Max value in last 24 hours PM 2.5 value
$purpleair2_5 = ‘25.3’; //Value of 2.5 micron particle measure from purple air sensor (see in WD under setup, advanced/misc)
$purpleair10_0 = ‘37.1’; //Value of 10.0 micron particle measure from purple air sensor
$purpleairaqi = ‘78.8’; //AQI (air quality index) value from purple air sensor
$purpleair60minmean2_5 = ‘%purpleair60minmean2_5%’; //Last 60 minutes average PM 2.5 value
$purpleair60minmean10_0 = ‘%purpleair60minmean10_0%’; //Last 60 minutes average PM 10.0 value
$purpleair24hourmean2_5 = ‘%purpleair24hourmean2_5%’; //Last 24 hours average PM 2.5 value
$purpleair24hourmean10_0 = ‘%purpleair24hourmean10_0%’; //Last 24 hours average PM 10.0 value
$purpleair60minmin2_5 = ‘%purpleair60minmin2_5%’; //Min value in last 60 minutes PM 2.5 value
$purpleair24hourmin2_5 = ‘%purpleair24hourmin2_5%’; //Min value in last 24 hours PM 2.5 value
$purpleair60minmin10_0 = ‘%purpleair60minmin10_0%’; //Min value in last 60 minutes PM 10.0 value
$purpleair24hourmin10_0 = ‘%purpleair24hourmin10_0%’; //Min value in last 24 hours PM 10.0 value
$purpleair60minmax2_5 = ‘%purpleair60minmax2_5%’; //Max value in last 60 minutes PM 2.5 value
$purpleair24hourmax2_5 = ‘%purpleair24hourmax2_5%’; //Max value in last 24 hours PM 2.5 value
$purpleair60minmax10_0 = ‘%purpleair60minmax10_0%’; //Max value in last 60 minutes PM 10.0 value
$purpleair24hourmax10_0 = ‘%purpleair24hourmax10_0%’; //Max value in last 24 hours PM 10.0 value
I have an SDS011 sensor and reading the values with a python script. In python, I output the values into a json:
# append new values
data = {'sensordatavalues':[{'value_type':'SDS_P1','value':str(values[1])},{'value_type':'SDS_P2','value':str(values[0])}]}
In WD, I use this json file (and the “Luftdaten” option) to log the PM2.5 and PM10. Works nicely with latest build (Nov16). However, I do occasionally (actually quite often) get zero readings in WD. To verify my data was “produced” OK, I log same values at the same time into a separate txt file with a timestamp. I do this at one minute interval. In my log file, there are no zeros.
Is there any way to detect if the json file is corrupt (hence the zero reading) or ?
I also modified my script to output integer values only but the zeros were still there.
Alternatively, is there a way that airquality2.txt could be used for the PM10 in addition to PM2.5 ?
That’s good news It’s probably not 100% guaranteed, but the chance that the file is unavailable should be greatly reduced. You could also try offsetting the file creation time some seconds from the top of the minute.
Hi Brian
Many thanks. I now have my Luftdaten running and both the 2.5 and 10 results completely agreed with the unit data. Actually I had an extreme test - the sensor is running indoors for testing (and yet to add the temp/hum sensor) and I had just lit my woodburner for the first time this year. I forgot to clear the dust out from under the top cover which then burnt off and filled the house with smoke. 2.5 and 10 were off the scale !!!
For some reason the 10 level has stopped showing as a figure but shows on the graph.
A request - any chance of having a second 10 needle on the dial ? Or an option to display the two.
Thanks again
Alan
Hi Brian
The scale on your dial stops at 500 but my 2.5 reading was up in the 700’s - hence off the scale.
I also realise that the 10 sensing must happen at a different time as it did show up on the view purple screen (I had just changed the config of the particle sensor which resets the sensor - I had just reset mine to 5 minute intervals).
Is there a way I can put the readings on my site in figures ?
Rather than a second needle on the dial would it be possible to create a 10 dial gif for use on the website - not necessarily shown on the view purple screen.
Regards
Alan
Hi Brian
I noticed the AQI line does not appear on the webfiles graph.gif.
Would it also be possible to add the scale to the side of the main screen graph. One small point the AQI figure just above the graph is a fraction too high and gets hidden by the wind direction graph.
Thanks a lot
Alan
