In the local LAN, the last data measured is retrieved by IP /data.json
{"software_version": "NRZ-2018-111", "age":"23",
"sensordatavalues":[{"value_type":"SDS_P1","value":"10.33"},{"value_type":"SDS_P2","value":"7.43"},
{"value_type":"temperature","value":"16.50"},{"value_type":"humidity","value":"84.60"},{"value_type":"samples","value":"637531"},{"value_type":"min_micro","value":"224"},{"value_type":"max_micro","value":"26690"},{"value_type":"signal","value":"-39"}]}
One can also download the data from the luftdaten sensor database : http://api.luftdaten.info/v1/sensor/_sensor_/
Example my own sensor: http://api.luftdaten.info/v1/sensor/8993/
This json data will contain the measurements received in the last 5 minutes (often 2)
[{"sensordatavalues":[{"id":4470568566,"value_type":"P1","value":"10.33"},{"id":4470568569,"value_type":"P2","value":"7.33"}],
"sampling_rate":null,"location":{"id":4532,"altitude":"16.4","longitude":"4.7000","country":"BE","latitude":"50.8860"},
"id":2098126748,"timestamp":"2018-10-14 06:09:52","sensor":{"id":8993,"pin":"1","sensor_type":{"name":"SDS011","id":14,"manufacturer":"Nova Fitness"}}},
{"sensordatavalues":[{"id":4470591803,"value_type":"P1","value":"12.13"},{"id":4470591804,"value_type":"P2","value":"7.20"}],
"id":2098137815,"timestamp":"2018-10-14 06:12:21","sensor":{"id":8993,"pin":"1","sensor_type":{"name":"SDS011","id":14,"manufacturer":"Nova Fitness"}}}]
Sensor P1 measures pm10, sensor P2 measures pm2.5
