I have set up WD with the Davis Vantage Vue, which has been up and running with data logger for a while now. It seems to be working fine, but I noticed that the year to date and month to date rainfall totals only read from the time that I first started the WD software. How to I download the data from the Davis data logger so that it displays the YTD and MTD values in WD? Or does it have to be entered manually?
You can try by going to your WD Control Panel.
Choose Off Sets/Initial Rain
Enter values from your Vue Console for month and/or year.
Click Set after entering value.
When done for both, click OK (Saving your values)
WD will change to those values.
Thanks for responding.
The way that ended up working for me was “Actions”, “Setup rain totals”. The values didn’t change when I did the way you suggested.
