if you se at the structure the 65 is now 00, i have a heated version and it was enabled H2 setting but i did not power it, so i guess 65 is an error code of some sort, teling me there is somthing wrong, and breaking somthing for weatherdisplay.
Else i did not get it to work whit windobserver as Id A but it works ok whit Id Q
the id can be changed whit a terminal program(hyper terminal), connect to the instrument and issue a * it enters configmode, then press N followed by the id you want Q as we have to here. and then Q to quit configmode
when i get the 24v power I’l test whit heater on and se if it stops working agen.
Hope this helps others trying to get the windobserver II working.
