Exceptin EOLEsysError in module WeatherDisplay.exe
After upgrading Windows OS I’m unable to run Weather Display:
Faulting application name: WeatherDisplay.exe, version: 1.40.0.0, time stamp: 0x5b92b732
Faulting module name: KERNELBASE.dll, version: 10.0.17763.1, time stamp: 0x30bd5043
Exception code: 0x0eedfade
Fault offset: 0x0011aaf2
Faulting process id: 0x600
Faulting application start time: 0x01d45c9201131784
Faulting application path: D:\WeatherDisplay\WeatherDisplay.exe
Faulting module path: C:\WINDOWS\System32\KERNELBASE.dll
Weather Display v10.37S (same issue with previous versions)
OS Windows Version 10.0.17763.1
Davis Vantage Pro
Davis Vantage Vue connected by USB
do you happen to use a web cam with WD?
No, only Davis Vantage is connected through USB->COM
as a test
try
install to a new directory (via the full install)
then create a file their called
2wd.txt (makes sure its not .txt.txt (i.e disable hide known file extensions)
so that then WD will start up their with no settings, like brand new, as a test
Installed in new folder and created 2wd.txt
are you sure the file is called 2wd.txt
and not 2wd.txt.txt
ie, make sure to unset to hide known file extensions in windows
Yes, I’m sure
D:\WeatherDisplay2>dir *.txt
Volume in drive D is DATA-01
Volume Serial Number is 28E1-5183
Directory of D:\WeatherDisplay2
08.10.2018 18.51 0 2wd.txt
29.12.2017 10.00 15 787 clientrawdescription.txt
07.02.2017 16.54 2 275 customclientrawlocal.txt
23.03.2003 10.07 854 ddenames.txt
23.11.2001 10.38 7 904 examplehtml.txt
27.07.2015 09.30 2 488 License.txt
06.10.2011 10.24 11 828 mywebpagetemplate.txt
29.01.2006 11.14 4 995 owntemplate-deutsch.txt
27.12.2006 20.55 6 682 owntemplate.txt
29.01.2006 11.16 5 157 pagepersonelle.txt
14.03.2017 06.54 5 928 readme.txt
12.01.2015 11.23 142 285 readmeacurite.txt
21.05.2008 08.53 795 readmedatabase.txt
08.11.2003 12.50 1 766 Realtimesvgviewer.txt
22.10.2001 14.20 8 087 samplecustomhtml-deutsch.txt
29.01.2006 11.16 4 405 spanishcustomwebpage.txt
24.07.2018 09.50 169 172 tagslist.txt
22.07.2010 18.47 40 644 testtags.txt
27.04.2010 07.35 486 universal.txt
14.11.2003 14.06 2 458 xmlhelp.txt
20 File(s) 433 996 bytes
0 Dir(s) 773 957 496 832 bytes free
using windows regedit.exe
is that a
wdisplayftp2.ini file in the registry and is there a wdisplay2.ini file in this 2nd install location
No wdisplayftp2.ini reference i registry and no wdisplayftp2.ini filer in new folder
that tells me that the 2wd.txt file is not setup correctly
What can possibly be wrong with 2wd.txt.
I have a video showing the file and whats happening when starting WeatherDisplay.exe
It is too large to upload. Kindly send me an email with info about how I can send it to you.
As you can see i screenshot, file extensions are not hidden
my email address is at the bottom of every forum post, in the signature
if the 2wd.txt is correct then I do not know what is wrong
it could be your virus checker or firewall blocking it even
are you running WD as administrator?
Yes, I’m running WD as administrator and WD has worked for years on Windows Server 2003 to Windows Server 2016.
After upgrading to Windows Server 2019 it stopped working.
I have tried running in compatibility mode and checked fw rules and Windows event log, but can’t see any issues or settings preventing WD to run
I’ll send the video to your mail address
Thank’s for working with me to try to resolve this!
the image you sent me mentions visual studio
but WD was not compiled with that
what program is creating that error?
have managed to fix this now
I had to remove a flash component
means you cant run the WDL bulit into WD now
Thank’s a lot for your help Brian!
You quickly nailed the error. Superb support!
Kjell Inge
