Is anyone else have problems with the Tides module of WD?
I have a problem, in that the file Tideprediction.html which is produced daily is showing dates for 2017 instead of 2018. It shows the correct month though the start date is a week or so early. The I7-64bit laptop running it shows the correct date. When I try to access the Tides section in the “View” menu I get a “dinging” sound and Weather Display freezes although it appears still to be gathering data. No tides screen appears, but the process of creating TidePrediction.html apparently happens at that point, which it does with the correct year and tide table. Control-Alt-delete and kill the process is the only way to deal with WD.
I upgraded (full install) to the latest version, 10.37S81 (I was on about version 56 before that) but I still get the same result. WD is producing custom tags for my web pages to show the current days tides without any problem.
Interestingly when I originally set Tides up, it was drawing data compiled for Lyttelton NZ (about 80 kms away as the seagull flies) with WD adding another 21 minutes for this particular area of the coast. The readings WD produces at present correspond to Lyttelton, so it isn’t doing any additional math. As I am unable to access the settings screen, I can’t check whether those settings still exist.
The I7 HP laptop with 8gb mem runs only WD plus Ispy with 3 IP cameras connected. It is used for no other purpose. The OS is Windows 7.
