I replaced my exe with the version above, as I said. Yesterday it was raining through the midnight to 9am period so I was able to look at the results. Unfortunately WU still reset to 0mm at 9am. Even more strangely was that the light rain continued through yesterday and early this morning, and on WU the rain seems NOT to have reset at midnight yesterday, but the precip accum value continued in to this morning.
There were also a couple of very odd numbers thrown in, suddenly at 10.00pm (4/10) the accum figure jumped first to to 7.6mm for a single reading, then at 10.40pm to 7.8mm for a couple of consecutive readings before in both cases going back to 3mm where it had been previously.
After midnight the accum total continued at 3mm, except for a couple of 0mm’s, until around 7am this morning, when the numbers started alternating between 0.2mm and 3.2mm (3.2mm being probably the actual total given the carry-over from the previous day), until just after 9am when the numbers changed to fluctuating between 0.2mm and 0mm.
I’m not sure if simply replacing the exe file was enough (have I got stuck between two versions?), or whether there’s something else going on, but any help would be greatly appreciated!
