Only Partial Data Being Received by Weather Display
Every seen this before, (attached)? WD is only receiving and displaying SOME data from my Davis weather station.
Now and then, Weather Display crashes and when I start it up again all the settings are gone. That happened recently. I had backed up my /wdisplay folder, so I just copied it back so that I wouldn’t have to re-type all the settings. That has worked before.
That’s about the time this ‘partial display’ problem started. Also, when I start up WD it runs the Data Logger, which it wasn’t doing before.
I have tried downloading the most recent WD install and installing that. But that didn’t fix it.
Gary
Please disregard. It turned out that somehow the ‘invisible’ data had been turned to black text on a black background. I would pull the post off the board, but maybe if anyone else ends up with this problem the solution will be helpful.
